i need help
Sirius
i need help
Post by Sirius » Wed Jul 30, 2014 6:49 pm
i have mounted a b18ft engine on a renault 12, with the complete electrical wiring for the 2 ecu`s.
a have the red "plug" in wich i have connected the + ignition and + fuel pump on the grey, and grey red wire.
the rest is correct, ignition coil, main 12v, all the earths are plugged...
a have one problem, im having low spark on the spark plug, while i turn the key... and itwont start.
any ideas...?
doingitsideways
Re: i need help
Post by doingitsideways » Wed Jul 30, 2014 9:14 pm
Sorry, I have no idea which wires you are referring to.
But have you checked the basics, like ignition coil, ht leads, distributor cap and rotor arm??
I would have thought that you would have spark or not, rather than weak spark if your problem was ECU related.
Steve :hopping:
Hammers can't fix a 480!!!
