Help with connector maf volvo b18ft
gt-tb18ft
Post by gt-tb18ft » Sun Jul 13, 2014 4:12 pm
Hello good buy an engine with full i switchboard wiring, and I have a problem came broken my plug flow or MAF i wanted to know if I can help you know the order of how they placead nd colors, my switchboards are orange aver if OK you can help me greetings
colors delos lost cables, brown, yellow, blue. white and blue, white and green, white, aver help if I know the order
doingitsideways
480 Expert
Re: Help with connector maf volvo b18ft
Post by doingitsideways » Sun Jul 13, 2014 5:02 pm
Hmm...
I suggest you give google translate another try! ;)
Hammers can't fix a 480!!!
gt-tb18ft
Post by gt-tb18ft » Sun Jul 13, 2014 5:45 pm
hello I bought aver one engine b18ft with wiring and ecu but I have a problem with wiring the plug of the flowmeter this broken and not the order of the wires going to the flowmeter anyone can help me the unit are orange ok thanks
Van
Post by Van » Sun Jul 13, 2014 8:01 pm
What languages do you speak, maybe a member can help you with the language.
gt-tb18ft
Post by gt-tb18ft » Sun Jul 13, 2014 8:55 pm
spanish
Slash01
Post by Slash01 » Mon Jul 14, 2014 6:44 am
This is the gist I'm getting from reading your posts.
You've brought a B18ft engine with it's ECU and wiring loom. I'm guessing your putting it in a Renault?
The ECU has the Orange Connector's.
The MAF connector is broken and you want to connect the wires directly, and are looking for which wires to connect together?
I can't help with the problem you've got but if this is basically it, it might help others understand what you after.
Ashley
There are always ample warnings and there are always subtle signs,
And you would have seen them coming but we gave you too much time.
gt-tb18ft
Post by gt-tb18ft » Mon Jul 14, 2014 7:57 am
Slash01 yes correct :wink:
gt-tb18ft
Post by gt-tb18ft » Mon Jul 14, 2014 8:04 pm
can anyone help me ?
gt-tb18ft
Post by gt-tb18ft » Wed Jul 16, 2014 11:27 am
Hello I have a photo of the wire aver ok if I can help
Robou
Post by Robou » Wed Jul 16, 2014 9:07 pm
Well, considering that your connectors are not original, that Volvo changed the wiring at random and that your MAF's number should end with 007, I better give you the connections as published by the time the orange ECUs were used:
1 is connected to ground
2 to Jetronic 6
3 to Jetronic 7
4 to Jetronic 8
5 to Jetronic 9
6 to Jetronic 14
Too old to bother
480 Turbo midst '91
glasgowjim
Post by glasgowjim » Wed Jul 16, 2014 9:44 pm
According to the data on page 14 of the wiring scheme and I crosschecked it with your diagram
MAF in dutch is luchtmassa-meter B14 on diagram
connection 1 is brown wire
connection 2 is white wire
connection 3 is white green wire
connection 4 is white blue wire
connection 5 is yellow red wire
connection 6 is blue wire
in spanish / espanol ...
conexión 1 es cable marrón
2 Conexión de cable blanco
conexión 3 es el cable verde blanco
conexion 4 cable es blanco azul
conexión 5 es el cable rojo amarillo
6 Conexión de cable azul
Espero que esto tenga sentido en español como pude a la Com traducción en línea.
No hablo español.
Espero que esto ayude.
gt-tb18ft
Post by gt-tb18ft » Thu Jul 17, 2014 7:33 am
hello many thanks perfect the perfect translation to Spanish thanks to all for your help :hopping: :hopping:
