fuel gauge showing one bar
POE
Post by POE » Fri Apr 18, 2014 4:18 pm
Hi all ' my fuel gauge on info centre is showing one bar permamently whether i add fuel or not ' checking fuel pump values ans all seems in order as are all connectors' any ideas? i have also changed the ic module to no avail ' thanks
Re: fuel gauge showing one bar
Post by glasgowjim » Fri Apr 18, 2014 7:19 pm
float may be stuck
doingitsideways
Post by doingitsideways » Fri Apr 18, 2014 8:34 pm
Either that, or the little wire to the potentiometer on the sender has broken.
Just changed mine today, bought a used replacement from Jim about 6 months ago, which I promtly broke when fitting back into the tank because the plastic mounting is so brittle! :(
Upon inspection of the old one, the wire had broken like I say, a bit of a combination of old and new, with liberal use of the soldering iron and only the foulest language and all is well :D
Steve :hopping:
Hammers can't fix a 480!!!
POE
Post by POE » Fri Apr 18, 2014 8:48 pm
Thanks steve and i shall have a damn good inspection and post results
doingitsideways
Post by doingitsideways » Fri Apr 18, 2014 11:49 pm
Just be VERY careful when lifting the pump/sender unit from the tank, if it frees up with a jolt (like mine did) the sender gets caught and snaps at it's mount :(
Steve :hopping:
POE
Post by POE » Fri May 30, 2014 6:02 pm
Well come to conclusion that my fuel gauge reading one bar and water temp gauge are connected sonewhat ' is there a voltage regulator that could cause this or maybe the circuit board itself? running out of ideas fast so any ideas would be great ' thanks
POE
Post by POE » Sun Apr 12, 2015 8:25 pm
Well after months of checking various info centres and fuel senders and wiring and sensors for engine temp have finally found the culprit in a block connector behind the glove box ' after opening up and cleaning everything Is working as it should 'even my rear wiper has come into life so this connector must play a big part in sending info to Ic' great weekend :)
