pop up - up and down...up and down
umpapa
Post by umpapa » Sat Nov 23, 2013 11:59 am
Hi all.
I have a problem with my car. I'm going to the car in the morning, I look and the left headlamp up and down .... up and down. The Light shone not only up and down. I opened the car and turned on the ignition. Next the same. When I turned on the lights then right headlight also began to dance up and down. When I opened the bonnet then dance headlights stopped. The bulbs are okay. Bonnet switch is ok. I took out the relay and conclude the conductor pins 87 and 30 - left headlight all the time up and down, up and down ..... Conclude the conductor pins 87 and 30a - right headlight all the time up and down, up and down .....
Please Help me.
Sorry for my english.
Re: pop up - up and down...up and down
Post by glasgowjim » Sat Nov 23, 2013 12:57 pm
First check your daylight driving lights.
Are both the bulbs lit ?
The bonnet microswitch is ok
The wiring from the relay to the motors is ok
Now check out the relay as that is the now the most likely defective part.
What language do you speak ?
umpapa
Post by umpapa » Sat Nov 23, 2013 2:59 pm
I'm Polish.
how to check the relay?
umpapa
Post by umpapa » Sat Nov 23, 2013 3:36 pm
1.( left pop-up)
Ignition off.
I removed the relay and bridge wire.
Rotary switch OFF.
Left pop-up moves up and down....up & dowan...constantly
2. ( right pop-up)
Another bridge wire.
Rotary switch off
Nothing happens.
Rotary switch on - Right pop-up moves up and down....up & dowan...constantly
Left pop-up moves when the rotary switch off.
