No wipers
pangapz
No wipers
Post by pangapz » Sat Oct 12, 2013 1:54 pm
hi, I have a problem with the wipers, rear does not work at all, the front on the lowest gear also does not work, turn signals are blinking like crazy, heated rear window did not work.
what could be the reason? I beg for help
Video Below:
http://www.youtube.com/watch?v=wiKyIYf- ... ata_player
glasgowjim
Re: No wipers
Post by glasgowjim » Sat Oct 12, 2013 2:03 pm
First is your battery charged ok?
No then charge it before checking again
Yes then it is most probably the wiper stalk that is at fault for the front wipers at least.
at worst it could be a CEM fault
the rear wiper can be due to several things
duff wiring loom at rear hatch.
wiper motor dead
fuse.
check all your fuses anyway as it is good practice .
Also we need to know the age of manufacture as the wiring change in 1992
Also I assume it is a 480 ?
You wont be able to post up pictures or video /links until you have a post count of at least 10.
pangapz
Re: No wipers
Post by pangapz » Sat Oct 12, 2013 2:18 pm
Battery is full, i think CEM is the problem but i dont know what to do to check where is the problem.
Big Brother
Moderator
Re: No wipers
Post by Big Brother » Tue Oct 15, 2013 7:41 pm
pangapz wrote:Battery is full, i think CEM is the problem but i dont know what to do to check where is the problem.
Hi.
PM me a link to the video and I'll add it to your opening post.
2001 V70
pangapz
Re: No wipers
Post by pangapz » Wed Oct 16, 2013 12:55 pm
Hi.
I have already try this but i also need to have 10 post at least.
Another problem, Central Lock and Alarm doesnt work :(
have no idea what to do ...
glasgowjim
Re: No wipers
Post by glasgowjim » Wed Oct 16, 2013 1:57 pm
Where are you located?
svenska axel
Re: No wipers
Post by svenska axel » Wed Oct 16, 2013 2:06 pm
check your earth connections to car body. common for them to corrode on old cars, can stop any number of things including alternator starter engine battery charge anything. could be giving the cem a low voltage. if things happened at once, theyre usually connected to a common problem. worth cleaning the body/engine battery earth straps anyway for good running.
good way of checking specific components for this just jump some wire from main -ve terminal to battery - and see if it works. find main earth at cem and jump it straight to battery - with clean connections see what happens. fairly quick/cheap to do to eliminate the possibility. Earths are brown at the cem.
Big Brother
Moderator
Re: No wipers
Post by Big Brother » Wed Oct 16, 2013 7:41 pm
pangapz wrote:
Hi.
You can send a link through PM without having 10 posts
2001 V70
pangapz
Re: No wipers
Post by pangapz » Wed Oct 16, 2013 9:59 pm
glasgowjim wrote:Where are you located?
Poland, Lodz.
I sent you pm but there is spacebar before com, it was the only way
Big Brother
Moderator
Re: No wipers
Post by Big Brother » Thu Oct 17, 2013 10:01 am
Video Added
2001 V70
glasgowjim
Re: No wipers
Post by glasgowjim » Thu Oct 17, 2013 10:13 am
There are 3 other Polish members as far as I am aware on this forum
bigdickbuster
caleemPL
malkontent
try a pm to them as some of them might be close to you
