speedo sensor.
speedo sensor.
2 questions.
1.--- on manual car is sensor always in same position be it 1.7,2.0,n/a or turdo.
2.--- will a 2.0l 1993 work on my 1.7 1991.
Re: speedo sensor.
1---- yes
2----yes
2----yes
Re: speedo sensor.
ive found two dirrerent part numbers in the pdf. will the wrong one have the genie come out of my console with a puff of magic smoke.
Re: speedo sensor.
Until the end of 1992 de reference number of the speedo sensor is 3413744. Since 1993 the ref. is 3467846. But not sure if they are exchangable...
Re: speedo sensor.
what should the resistance be. if its high enough shouldnt do any damage. there are three car near me being broken but all 2.0 m reg which is what 93/94. anyone have a 1991 sensor id be much obliged.
Re: speedo sensor.
tested it and its open circuit, so now have to hunt down a replacement. thats assuming i can get it off, cant get any leverage on the allen key between exhaust and drive shaft.
Re: speedo sensor.
is it an auto / manual / turbo ?
Re: speedo sensor.
manual transmission, asthmatic.
