I took a picture of my relays, I noticed a few things...
I seem to have a relay missing?.. Think it's the Auxiliary Water Pump (B18EP/FP engines)/Relay, Auxiliary Water Pump (B18FT engine)
This only has 4 connection points.. Think this is the Inhibitor, Headlight Dim-Dip System
But seems to have an extra pin?
Relay question..
- jamesy12345
Re: Relay question..
edit: posted twice doh
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
- jamesy12345
hi Lee, I thought GT's had 2 litre engines? If so, I'm not sure they have auxiliary water pumps.
http://www.volvo-480-europe.org/forum/v ... ow#p198180
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Volvo S60 '04
Renault 21 '91
Subaru Legacy '05
Mazda RX-7 '93
Renault 5 '84
Hi Lee
Your relays are exactly as they should be. Or, at least, they seem identical to mine in my Celeb and everything works as it should!
The 2.0 litre engine does not have an auxiliary water pump, hence no relay for one.
You are quite correct about the headlamp inhibitor relay - it is the one you have, and it does have an extra pin that is not connected.
Great thanks for that guys
