As my info centre is dieing and I get bouncing needles on both the speedo and tacho followed by nothing, I've decided to replace the whole instrument cluster with one that I hope will be better.
How do I wind my mileage ON from the 80k on the 'new' speedo to the 130k that matches the car and all my paperwork ?(I did a quick search for mileometer but drew a blank)
Mileometer change - winding it on ?
Re: Mileometer change - winding it on ?
The problem with trying to adjust it by stripping the unit down and moving the digits on is that they never align themselves properly but you can remove the motor and ease them apart to cycle them forwards only. please feel free to correct me if I'm wrong
1995 Celebration 332
Ok thanks. I decided to SORN it (for the first time) until the end of March so will have a look then.
If you take the speedometer / milage counter unit apart, you'll see something like this (unit removed from a 1986 480ES)
The stepper motor (brown) on the printed circuit board to the left drives the counters. I once used a small drill (dremel tool) with a small gear, to "play stepper motor" myself. I could advance the counter by a few thousands kilometers quite easily. Advancing the counter some 50,000 miles will take some more time, but can be done this way...
To be continued...
Peter
1986 Volvo 480es red 217
1987 Volvo 480es blue 219 (sold)
1993 Volvo 480 turbo automatic red 235 (project)
Peter
easier way to do this than you think ..
since no one increases mileage on the speedo all you need do is photograph the old instrument pod in situ then the new one in place and print out the 2 digital photos side by side on the same A4 sheet of paper and then make it into a certificate of changeover sign and date it.
that way the problem is solved the easy way. When I supplied a replacement speedo I also produced a certificate of mileage.
Ok, thanks to you both.
