just aquired a gauge pod for my car:
just pushed it in just now as it already looks better than the useless tray that was there
this is the plug that came with it
what do i wire what to- also i assume the power to give the battery gauge a reading powers the illumination? does the car already have a oil pressure sensor or is that something ill need to get?
Nick
wiring a gauge pod
wiring a gauge pod
very proud owner of:
flame red celebration No. 63- daily driver and only car i own that is on the road
white celebration No. 54 - spares/parts car
Cadburys purple Saab 9000 CD Turbo - rapid toy currently in storage
Saab 9000 CSE - for saab spares!
Re: wiring a gauge pod
search behind the tray you removed the wiring loom is already there it will be a three or four wire plug been some time since i installed mine
voltage will work straight away oil pressure will need a sender unit installed instead of the oil pressure switch
Harriet is right you will need a sender unit +mounting.
This might be difficult to find .
- Captain Slow
Best bet is to find a turbo thats being broken as the sender for the turbo engine is the same (its just to the 7 O'clock position realative to the oil filter)glasgowjim wrote:
Previously....
ah right- ill go and try that once the rain stops,
many thanks
Nick
many thanks
Nick
