Dashboard/clock bulbs
Re: Dashboard/clock bulbs
Hi there,
I've just bought a 480 today, the bulbs seem to be gone on the centre console and the "bulb out" icon is illuminated on the dash. All exterior bulbs are fine (it would seem!) so I'm assuming it's the interior that's the issue. I'd like LED ones and to be honest I'm totally new to this and any help would be awesome!!
Thanks in advance.
Des
Thanks in advance.
Des
The 'bulb out' indicator is lit when the monitoring circuit detects an open circuit lamp. The lamp failure module is in the boot, on the left hand side ahead of the aerial near the wheel arch. It's sort of a dark red colour.
The module only monitors some external lamps - park lights, brake lights, day running lights by memory. The 'bulb out' lamp will light if one of those lamps is faulty.
- spree
Yep the bulb out light is for exterior bulbs. Have you checked the brake lights properly as its obviously hard to check these without help.
I can sort you out with led courtesy bulbs if you want them.
if all bulbs out on dash check fuses first
Can supply dash bulbs if needed.
oh there is a how to on removing dash in how to section
Thanks fellow 480(ers), is there a collective noun for us?
It would appear that when I brake and indicate at the same time those behind me are treated to a free disco show! I have sourced bulb holders and hope to fit them soon.
Spree I messages you on Facebook last night for advice as I like the look of the LED ones.
I couldn't see a how to on the forum but I am on a tablet and dashboard search only brings up this thread.
Thanks again for all your help.
Des
Des
The disco lights problem is almost certainly due to a faulty earth, there are two places to look and you have to remove a bit of trim to get a good look:
1. the earth point on the chassis, lh rear corner. It's like Stonehenge for want of a better description - 4 terminals standing upright and arranged in a square. Rust can be an issue here due to the 480s propensity for leaking
2. the earth connections on the lamp holder connector. By memory the central connector in the block is earth and they burn/corrode/go manky. This is fairly easily fixed by soldering a jumper over the connector - once it starts to burn/rust it will never be reliable.
Got a 480 and you will be chasing electrical faults and leaks forever. They make Alfas look well made. I've had 7 480s and they are all the same for leaks and weak electrics....and I can't imagine they're any better in Europe where the conditions are harsher.
Thank you for the replies.
I will get it into my garage at the weekend and take the rear trim out, hopefully the new bulb holders will be here by then too. It has had the rear floor replaced as well as the back arches, I hope they haven't moved the earth!
If the earth has gone moved cant be found can supply the earth point for you it is a cheap part.
