no spark on a 1989 ES
BobDeere
Post by BobDeere » Sat Aug 13, 2011 6:02 pm
Hi all
my name is Robert and im totally new in Volvo .. but i came across one 1986 ES that had the head broken..
so i ended buying a 1989 white ES with only 100.000 km on..
the car is in quite good condition. with no rust..
anyhow.. there is no spark..
i have tryed following..
new distributor cap.
new rotor.
new spark
i also have tryed to see if i get any light from a bulb attached to the low voltage module .. but nothing there
i measured the Ohm of the sensor attached to againt the flywheel and it was ok..
BUT.. the contact that is connected to the low voltage module behind the coil gives only 170 mVolt instead as 300-400 as the Haynes book indicate i should get..
any idea if these is the problem? how do I increase the voltage?
I have disconected the computer box located in the compartment but i the connectors looks nice..
Thanks for your help
Robert
Re: no spark on a 1989 ES
Post by glasgowjim » Sat Aug 13, 2011 9:21 pm
ignition relay and fuse under dashboard.
BobDeere
Post by BobDeere » Sun Aug 14, 2011 5:42 am
sorry for the newbie question..
but where can i find the ignition relay?
and the fuse? is it the one placed on the left side far below and with a mirror?
regarding the fuses.. i looked in the Haynes manual and as far i can see there is no fuse connected to the ignition..
or am i missing something here?
Robert
Post by glasgowjim » Sun Aug 14, 2011 9:37 am
yes you possibly are :lol:
Older models of 480 had a smaller number of fuses in fusebox so they had 2 located as shown in the photo the relays had a fuseholder on the back .
Have never worked on a pre 92/1 car so there may be slight differences so check your owners handbook as HBOL is not very good for a 480 :rofl:
BobDeere
Post by BobDeere » Sun Aug 14, 2011 9:51 am
never heard about that second fuse box.. thanks glasgowjim !!
for the relays fuseholder at the back.. is that behind the spare wheel?
Robert
Post by glasgowjim » Sun Aug 14, 2011 11:30 am
The fuses are on fuseholders behind /on top of relay fixture. That is what I meant by the back not the back of the car.
These are found under the dashboard at drivers far right hand side . The picture is taken from the drivers footwell looking upwards.
BobDeere
Post by BobDeere » Sun Aug 14, 2011 11:50 am
sorry to be a pain..
but you mean the regular one provided with a mirror??
or is it another one further up more close to the relays?
still.. i dont understand how the relays or the fuses can generate just half of the current..
thanks for your help
Robert
Post by glasgowjim » Sun Aug 14, 2011 1:18 pm
what do you mean by
the mirror is baffling me?
Post by glasgowjim » Sun Aug 14, 2011 1:31 pm
as a matter of imterest when you turn the ignition on does the starter motor turn over ?
BobDeere
Post by BobDeere » Sun Aug 14, 2011 2:13 pm
since i live in Sweden my car is left hand drive..
and i have the fusebox way down.. almost at the floor. since its so low its provided with a mirror so its easier to see the fuses..
and yes the starter turns..
actually almost everything work in the car "but not the pop up lights, they are up all the time"
but no spark.. not even at the coli..
Post by glasgowjim » Sun Aug 14, 2011 10:22 pm
Hej Robert
did not realise that you were writing in a foreign language :D
Although your car is LHD the body work and wiring were reversed round. Your car will have 2 fuses clipped onto the relays which on your car will be above the drivers left hand foot behind the dash board. If they are ok the complete check list would be ...
1 fuses
2 coil
3 distributor cap and rotor
4 check alternator and battery because if the voltage drops too low when the engine turns over the fuel ECU will not receive enough voltage to activate the coil.
5 check earths
if all else fails then replace the fuel ECU they are on sale on UK ebay for £20 each.
Hej Robert
1 fuses
2 coil
5 check earths
6 almost forgot what about the capacitor connected to the ignition module?
BobDeere
Post by BobDeere » Mon Aug 15, 2011 5:40 pm
Ok..
update of the parts checked:
1 fuses all ok as far i can see..
2 coil dont know.. but only 220 mVolt on the low voltage part and 12 volt on the other contact
3 distributor cap and rotor.. exhanged
4 check alternator and battery because if the voltage drops too low when the engine turns over the fuel ECU will not receive enough voltage to activate the coil. new recharged battery but only 220mVolt measured
5 check earths as far i can see everithing is ok..
6 almost forgot what about the capacitor connected to the ignition module? i dont have any capacitor connected there,only a black wire connected on one of the screws that
fasten the ignition coil on the low voltage part
i also took apart the computer module and used contact cleaner spray on the connections.
still no spark...
I have another car that was in use before the cambelt when off..that car is a 1986..
have those 2 cars interchangeble parts?
thanks for your answers
Robert
Post by glasgowjim » Mon Aug 15, 2011 6:27 pm
Is your car have a 2 litre or a 1.7 litre engine ?
BobDeere
Post by BobDeere » Mon Aug 15, 2011 6:44 pm
not sure but i think its a ES 1.7 with no turbo
actually both cars i have are that .. i think..
but how can i see that?
Post by glasgowjim » Mon Aug 15, 2011 10:39 pm
use the vin reader
http://volvo-480-europe.org/volvo480/vin_reader.php
vin = vehicle identification number
BobDeere
Post by BobDeere » Tue Aug 16, 2011 5:05 am
its a B18F-106 engine
Post by glasgowjim » Tue Aug 16, 2011 7:41 pm
Found this on an old folder it has a picture but it will not post up so send me a pm with your email address and I will reply with the full word document including picture . :lol:
Facts / Tips & tricks
Identified relays
The relaybox on my 1989 480ES (Sweden) from no. 529392. The relays are not described in the car-manual or Haynes repair-manual.
Attention, these relays change according to modeles, in particular from the models on 1994 (No. 581011)
Relay-box overview
1. Hella Lampcontrol 12V, Class 3, 448130, 5KG005918-01, Running lamp 2x21W
2. ABS Pump-relay
3. foglights (white for the Netherlands (3,08 Silver), for Europe (3,12)
4. 412653 12V/20A, Popup-lights
5. Wehrle 59205001, Electrical water pump (EP/FP, red:3,16)or(FT, yellow:3,22)
6. ABS pump, electrical relay mark 2 (3,09 red)
7. Empty, What for? (antifogs rear (NEDERLAND 3,07)
8. Air conditioning for european cars (3,05), earlier antifogs for the Netherlands(3,12)
9. Pop-Up relay, 5DS0050053-00
10. Wehrle 20 210006, Ignition relay contact 15 (3,03)
11. Wehrle 20 210006, Fusebox relay contact 75 (3,04))
12. Contact for diagnosis ABS mark 2
BobDeere
Post by BobDeere » Wed Aug 17, 2011 4:57 am
ill have pm my mail address Jim..
you mention 11 relays but on my relay box "the one triangle shaped" there is only 5 relays.. where do i found the other ones?
Thank you so much for your help..!!! :)
ps. tried to PM you but it doesnt work .. so here is my email address
email has been sent so for security reasons the email address has been deleted GJ mod
cheers
/R
Post by glasgowjim » Thu Aug 18, 2011 5:32 pm
email sent . relays are only used if the car has that feature eg ABS
