a question: is the switch near the gearshift mechanism, under the actual transmition the one? do i have to drain the gearbox oil to remove the switch? i got manual trans.
thanks, bYe!
reverse light switch
- bbf
'86 480 ES, RIP :(
'91 480 Turbo, RIP :(
'93 480 2.0, RIP :(
'86 480 ES, RIP :(
'93 480 2.0, RIP :(
- kingrichy
If you stand for the car, it`s the switch on the right of the gearbox.
If you take the wheel of you can see it.
I think if you take the switch out, the box is gonna leak oil.
But if you have a new switch, you can change it without leaking to much.
My baby`s
1990 Red ES Automatic 145000km
1990 Lavendel metalic 223000km
1988 Grafite gray metalic Turbo 185000km Sold
http://img20.photobucket.com/albums/v60/kingrichy/
Re: reverse light switch
does a faulty switch result in the reverse light staying on even if the car is turned of ?
if how much does one swith cost and/or is repair possible ?
tip of the hat
tip of the hat
- blackbelt1990
Id have thought that would have something to do with the power source or the earth than the switch. There shouldn't be any power when the car's off.Zerbot wrote:does a faulty switch result in the reverse light staying on even if the car is turned of ?
tip of the hat
My 480 doesn't break... it just rests
[img]http://i56.photobucket.com/albums/g181/blackbelt1990/Volvow/sig.jpg[/img]
