Problem with Info Centre
bigdickbuster
Post by bigdickbuster » Sun May 08, 2011 9:20 pm
Hello. This is the message from my friend, which is a 480 user, registered on this Forum, but he lost his password and have no possibility to access.
In my car S 94' I hadn't originally IC but bought it, colors of plugs are the same as in car: green and gray. Speedometer, tachometer and odometer are working. Avg speed, range, external temperature, oil and engine also working good. I have problem with average and instantaneous consumption. Average consumption still show 0 liters / 100km. When the car stops at a red light inst fuel show "- - -" and when i move inst fuel after a while show "0 liters / 100km"
I checked injectors signal from ECU (26 pin) and in grey plug (5 pin) in instruments and multimeter shows voltage 14.3-15V.
What can I check more to fix it?
Any ideas will be appreciated :)
Regards, swital and bdbuster
Captain Slow
Re: Problem with Info Centre
Post by Captain Slow » Mon May 09, 2011 9:59 am
The fact that it shows '- - -' when stationary and zero when moving shows that its getting a speed signal for the consumption calculation.
Previously....
Iroll480
Post by Iroll480 » Mon May 09, 2011 10:55 am
Probably the MFU on the back of the infocentre is broken or has a bad connector. The MFU calculates the fuelconsumption from the info coming from the ecu and speedo sensor.
suddy
Post by suddy » Tue Jun 07, 2011 6:22 pm
Make sure that the MFU (the little circuit board under the white cover) matches the one for your car.
For example. If you use one from a Turbo and you've got a 2.0, it won't calculate MPG, atlthough the rest of the settings will work. This sounds like the behavior you're experiencing..
This will help you
http://www.volvo-480-europe.org/volvo48 ... ment_panel
Stephen
1995 480 S 2.0 220,000 Miles
