color matched cem´s
Duke of Cruel
color matched cem´s
Hey everybody,
If i color match my boxes, can i use any boxes in my 480? Or wont the later work in the olde ones, and how about the 440 and 460, can i use the boxes from them?
Duke
Duke
Volvo 480 1990, Vovo 855 t5
Re: color matched cem´s
440 + 460 's dont have CEMs hence there are less electrical gremlins in the 440 +460.
Toys:-
94 440 turbo auto (Sent to the main dealer in the sky
do you mean the
CEM
Boost ECU for a turbo
Fuel management ecu
CEM
Fuel management ecu
Duke of Cruel
That are no CEM's. The cem (central electronical module) controle electrical things like rearwindow heating, wipers, blinkers, alarm, electrical windows etc but have nothing to do with the engine management and are only used in the 480 like bkf_uk said. The boost and fuel ecu's can be replaced for the same coloured ones from the 440/460/480 turbo's.
Duke of Cruel
ok, i found a 460 turbo from 95, and when i went under the console,, the boos box was blue, and the fuel box was green? Can i use the green box with a blue box? The 460 in question couldent strat.
The combination is right. Not starting could arise from anything. The particular set will need a lambda sonde connected. Your '90 480 may not have one.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
Duke of Cruel
Its a swedish car, so it does. And ive bought an blue box, and an green box, so i hope everything is going to be sweet
