Speedo problems
Speedo problems
I own a 1993 480 ES 2.0i and recently had to get a new clutch. this wasn't cheap and when I got the car back the speedo doesn't work anymore. the garage says everything is connected up and should be working fine but it isn't and they want another £100 to fix it which is bloody rediculous since they messed it up in the first place . You got any ideas at all on how to fix this annoying problem. Cheers.
- coyote1980
- Volvo 480 Club Europe CREW
I would tell them to fix it or give the money you paid back, charging for problems they started is not allowed here.. If the garage is part of a larger branche-organisation I would contact them and explain what happened. Or inform the garage you would do so if they don't fix the problem they created.
- strangegame
the sensor for the speedo is located behind the starter quite hard to get to you will need little fingers .-- but as Coyote says - speak to the manager or even better if they have a head office , get in touch with them . they must know what is wrong---- (what they did ) ---if they quoted you a price on the repair
