GPS navigation
GPS navigation
I want to install a navigationsystem in my 91 480T, does anyone know if there is a signal (called GAL) to feed this navigation system.
Eric
Eric
- coyote1980
- Volvo 480 Club Europe CREW
Hi Eric,
what's this then, "GAL"? Have GPS in my 480 using a pocketpc and TomTom Navigator 2, works like a charm! And better: isn't that expensive actually (might do a page about GPS solutions in the 480 when I have time...).
Off topic: found the CD with photos you took in 2000 of the first ever Volvo 480 Club EUROPE meeting Shall I post a copy back to you? If so, please mail me your address
Navigation
GAL means Speed signal (electronic), It's standard on all modern cars.
It just come out of the ISO-DIN connector, PIN 1
- coyote1980
Navigation
I'm not sure, this signal also increase the volume if you make more rpm's.
VDO and Becker system always use this signal. (that's what the manual says).
have a look at
http://www.becker.de/beckerCC21/www_roo ... %20CD5.pdf
It's in dutch, but it will show what I mean
Eric
have a look at
Eric
- coyote1980
There’s a speedo signal in the car ,
Also known as the cruise control signal , I think you will need a pulse amp.
As the speedo feed works, to the gps device , you tripcomputer looses the av. Speed function ect. ( mine did )
I have to look up the precise wire / pin
Gr,b
Gr,b
it ain't got the power, if it ain't a turbo
