Starting problems some progress but PLEASE HELP !!
- grafi
Re: Starting problems -- PLEASE HELP !!
the maf connected to the rubber tube coming from the air filter housing.
you can check easily if its work, or not:
- start the engine.
- unplug the cable going into the maf.
- if the idle starts moving, or strugling, or something happens, then it works. (after a few seconds, the computer will correct the changes, so the idle will be normal again without maf connected.)
- if nothing happens, there is a problem.
remember, it is a simple check, only shows if the maf is dead, or not. Obviously, if you dont have smooth idle, you wont see if there is a change.
By the way, I asked around about your problem, but unfortunately I did not hear any new advices, just the ones wich were in the topic already. :/ Sorry.
- start the engine.
yeah it idles fine.. so I should see a change.grafi wrote:the maf connected to the rubber tube coming from the air filter housing.
- start the engine.
Ok, thanks anyways mate
Starting problems
Hello mates,
Still having very strange starting problems..
After a lot of fiddling this is the situation -- car will start when cold (but needs alot of cranking!) but will not start when warm ! Once the temperature sensor is unplugged it starts immediately but has a veryyy rough idle - plug it in again and runs very smooth. Even if the engine is completely cold, if the temperature sensor is unplugged it needs far less cranking to start. Once its running, its idles and runs very good!
Ignition is always OK, problem is fueling (only while starting -- once its running everything is OK)
Temperature sensor brand new, original BOSCH.
Wiring to & fro temperature sensor all correct.
Brand new MAF.
Brand new starter motor.
Any thoughts please ???
Brand new MAF.
Nothing ?
Re: Starting problems some progress but PLEASE HELP !!
Can anyone help here ?
- grafi
try another ecus. both plastik and metal.
Already done that .. same problemgrafi wrote:try another ecus. both plastik and metal.
still with problem - now even worse!
Car will take a lot of cranking to start and if turned off once warm it will not start again ! Only will start if the temperature sensor in unplugged .. and then plug it back in once it is started.
Once started runs veryyyyy rich !!
List of stuff recently checked & replaced;
New MAF
New temperature sensor
New starter
New spark plugs
New coil
Leads, dizzy cap & rotor arm all good
New fuel pump
New fuel pressure regulator
Changed both ECU's - still same problem
inspected wiring loom - all good
Problem is fuel related - ignition is OK
Please help meeeee !!!!!
New MAF
New starter
New spark plugs
New coil
New fuel pump
Did you renew the fuelpump relay?
480 Turbo 1991 305
- grafi
Would you be so kind as to explain? This is new to me, and I have some fuel related problems as well.dutmanjf wrote:Did you renew the fuelpump relay?
Thanks!
there are 2 relays clipped up underneath the dashboard in the lhd car as you sit at drivers seat it is up to the left of your instrument panel. Lie with head in drivers footwell and shine up , one is ignition relay the other the fuel pump relay.
go to 480 club europe home page select downloads then down load the fuse box relays by either myself / esta best do both as there is an ignition relay there as well as the 2 underneath , oh if you have aircon there could well be 3 relays.
http://volvo-480-europe.org/volvo480/downloads.php
or even better look at this thread as I have a photograph of the location posted dated Sun 14th Aug 2011
http://volvo-480-europe.org/forum/viewt ... 12&t=33043
Thanks Jim And for the LHD it's much easyer to remove your glovebox for some workspace.
480 Turbo 1991 305
