elecric window winder cable
Hello,All,
This is my first post since becoming a member and having read lots of the forums,I,m sure that someone can help.
I am the proud owner of 94GT 2.0 model,having bought it in November.
My problem at the moment is that the cable on the passenger window looks like it has slipped off and is very loose.
Does anyone have a diagram of the mechanism,especially the route of the cable?Any advice would be more than appreciated.
Thanks in advance and regards,
Tom
Tom
tried the rest.now got the best.
- Ben Harris
- Ben Harris
- Ben Harris
I had to replace both mechanisms for my electric windows. I had a similar problem to you i think, i heard a horrible crunching sound when i tried to operate the windows, and the high tension cable was very loose. This is because both times, a small piece of white plastic which connects the cable to the window lift mechanism has cracked and therefore failed. I found this was quite irrepairable. I hope you have better luck though!
post subject
Hi,I,ve ordered a new set of cables and drum from these people.Worth a look!
www.mx5parts.co.uk
Tom
www.mx5parts.co.uk
Tom
