Hello,
Can I just make sure that an alternators from the turbo and the the 2litre are the same?
Cheers.
alternator
alternator
- bigdickbuster
Re: alternator
Basically, I can say yes. But you need to check empirically, because Volvo used few types of alternators - several types with different values of amperage for example.
Pulleys are with three or five incision. And last but not least: Different types of start of charging. There was self starting alternators and second type which need impulse to start the charging. Difference is in the number of contacts on the alternator.
Producers of alternators:
-Bosch
-Valeo
-Paris-Rhone
-Bosch
-Valeo
-Paris-Rhone
Last edited by bigdickbuster on Tue Jan 11, 2011 12:41 am, edited 1 time in total.
Re: alternator
Ah, bugger. That's not gonna work then as the 2litre has AC.
Thanks for the replies guys
Re: alternator
You can change the pulley to make it fit.
Re: alternator
Hi....could you elaborate please? Basically I have a 2litre with a poor charging alternator and a recon from my old turbo...what would it involve to use the recon?? Cheers.
Re: alternator
Hate to rain on anyones parade but the alternator for an aircon car has a bigger output than the alternator from a non air con.
Basically you can put an aircon alternator in any 480 but you cant put an a non air con alternator in an air con car as it has a lower current output.
Also as had been said earlier the pulleys are different and they would need to be changed over ( not a hard task ).
Re: alternator
You're right James, I forgot that the airco alternator has a higher output then the non-airco one!
Here you can download the alternator and startermotor manual with faulttracing. I suggest you to check the brushes and voltageregulator. They can be changed without removing the alternator, costs will be something like 25 quid for a new regulator and brushes. Not a difficult job.
