central locking probs
Yozman2000
Post by Yozman2000 » Thu Jan 28, 2010 5:25 pm
when i lock my car the passenger side door locks and then unlocks or doesn't respond at all :angry: . is this cem related? or am i barking up the wrong tree? :roll:
Again thanks in advance :hopping:
Yozman2000@hotmail.com
Black 1990 Volvo 480 es 1.7
H*** VJX
TT 1993 480 es ltd edition 2 ltr
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
1998 Volvo s40 1.8i Gdi
Raffadakis
Re: central locking probs
Post by Raffadakis » Sat Jan 30, 2010 12:39 am
Searching the forums would have let you to the answer ;) As there is only a locking motor on the passenger side, you can only central lock the two doors, if you use the driver's side lock (this will activate the locking motor on the passenger side) ;) Well using the lock on the passenger side should at least lock the passenger side though :tomato:
Greetz
Raff
Yozman2000
Post by Yozman2000 » Sat Jan 30, 2010 8:18 am
Perhaps i wasn't clea :bla: r, i meant that when i lock the drivers door the passenger side door locks and then unlocks or doesn't respond at all. :wall: :wall:
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Raffadakis
Post by Raffadakis » Sat Jan 30, 2010 4:49 pm
Yozman2000 wrote:Perhaps i wasn't clea :bla: r, i meant that when i lock the drivers door the passenger side door locks and then unlocks or doesn't respond at all. :wall: :wall:
Hmm this might be caused by the CEM. Althouhg might be only bad contacts/wires.
Quagmire_GT
Post by Quagmire_GT » Sat Jan 30, 2010 7:51 pm
Also car is cutting out and the auduble clickin on the indicators have stopped... :shock:
M*** PRA, 96 GT Maroon owned
K*** TBJ, Donor 2.0l 2 tone
Pictures: http://s806.photobucket.com/albums/yy344/quagmire_GT
I MANAGED TO STRAP A CARDBOARD BOX TO A LAWNMOWER AND GET THE DVLA TO REGISTER IT, NOW LETS SEE WHO WILL BUY ANYCAR.COM!!
Yozman2000
Post by Yozman2000 » Sat Jan 30, 2010 7:52 pm
Right, will double check the door wiring in the morning. will keep you posted . cheers all
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Yozman2000
Post by Yozman2000 » Wed Feb 03, 2010 6:37 pm
Right, i have replaced the cem, still no better. am gonna start swapping over door parts with the spares i have now. indicator/warning noise has started working again, thanks quagmire gt
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Post by glasgowjim » Wed Feb 03, 2010 7:21 pm
Quagmire ?????
I am getting confused with the interlacing of threads here. The CEM does not affect the running of the car engine will work without a cem being plugged in.
this answer for quagmire not anyone else . If you want an answer go get your own answer :rofl: :rofl: :rofl: :rofl: :rofl: :lol:
Yozman2000
Post by Yozman2000 » Thu Feb 04, 2010 3:20 am
sorry quagmire gt is my brother who has been helping me fix the car. we had had a couple of "talks" about the cem i said that it only handled the electics NOT the running of the engine. thanks for clearing that up for us Jim
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Yozman2000
Post by Yozman2000 » Thu Feb 04, 2010 12:55 pm
right, have replaced all the electrics in passenger door and its still the same :cryhard: :cryhard: :cryhard:
any ideas?
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Quagmire_GT
Post by Quagmire_GT » Wed Feb 10, 2010 9:31 am
yeah Jim i only stated these other faults because they all came at once rather than seperate
Steve Long
Location: Bedfordshire, UK and St Aulaye, Dordogne, France
Post by Steve Long » Wed Feb 24, 2010 7:37 pm
Yozman2000, did you find a solution? My 95 GT started playing silly beggers yesterday.
I can unlock the entire car with the key in the drivers door but as soon as I open the driver's door the passenger's door re-locks itself and the alarm turns on (I can still drive it even when the alarm is on, turning on the ignition turns off the alarm LED).
If I then open the driver's door, the passenger's door unlocks - I close it, it locks again!
Sometimes none of this happens! We get in the car and all is normal, I start the engine and a few seconds later the passenger's door locks! Turn off the ignition and the alarm LED starts flashing immediately.
If I leave the keys in the ignition and get out of the car, chances are that opening the driver's door a second time in order to get back in will trigger the alrm leading to a demonstration of the car's horn!
My suspicion is that it is related to the driver's door courtesy switch or a fractured wire in the door loom. Any thoughts?
Steve Long
Also in St Aulaye, Dordogne
Yozman2000
Post by Yozman2000 » Thu Feb 25, 2010 3:46 pm
no sorry still had no luck. am gonna look at changing the wiring in the doors when i get some better weather. :(
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Renter
Post by Renter » Fri Feb 26, 2010 2:21 pm
I had similar problems with my drivers door a couple of years ago.
Turned out to be a faulty dip switch in the door lock mechanism. This upset the car in knowing if the door was locked or not and opened or closed the passenger door and alarm at will. (favourably in the middle of the night pissing the neighbours off)
They replaced dipswitch and problems solved.
Hope this helps.
Volvo 480 2.0 ES, 1995, Paris Blue
chriskay
Post by chriskay » Fri Feb 26, 2010 4:15 pm
Renter wrote:I had similar problems with my drivers door a couple of years ago.
Hope this helps.
To prevent confusion, the "dipswitch" has nothing to do with the lights & is more usually called a microswitch. (If I understand this correctly).
Cheers, Chris.
2 Kings; Chapter 9 Verse 20
Yozman2000
Post by Yozman2000 » Sat Feb 27, 2010 8:13 am
is that the switch in the keylock lock? if so i have replaced it. lol :cryhard:
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
Agwa Moose
Post by Agwa Moose » Sun Feb 28, 2010 1:50 am
Had the same problem on my TT
Replaced all the lock bits in the passenger door - no change
Went through as much of the wiring as I could find - no change
In the end the cure was simple...
Disconnect the central locking, problem solved
J
Yozman2000
Post by Yozman2000 » Sun Feb 28, 2010 8:45 am
its looking like a good idea the more i think about it! lol
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
ted clutch
Post by ted clutch » Tue Mar 02, 2010 2:11 am
Raffadakis wrote:Searching the forums would have let you to the answer ;) As there is only a locking motor on the passenger side, you can only central lock the two doors, if you use the driver's side lock (this will activate the locking motor on the passenger side) ;) Well using the lock on the passenger side should at least lock the passenger side though :tomato:
Greetz
Raff
this is not true on either of my es's. the drivers door can be locked from the passenger side. what model is yours?
Yozman2000
Post by Yozman2000 » Tue Mar 02, 2010 9:30 am
Mine is a 1990 es 1.7 and it only locks from drivers side. maybe newer models lock from both doors?
H*** VJX
K*** TBJ
Old cars
1989 Volvo 340 Glt
1990 Volvo 440
1992 Volvo 440
