Cruise Control - make the 'cruise' light work
- Melvin480
I've bought a complete original Volvo cruise control set which I'm about to install. My car also has the 'cruise' light on the dash so I want to make that work. I'm not sure where to tap the 12V needed for the light. I know that I can measure it, but if possible then I would like to add the wire to the loom before I place it in the car.
P2 = switch on indicator stalk
P3, P4 = pedal switches
P5 = vacuum pump
H9 = brake light switch
A63 = diagnostic point
4.0 = instument panel
I've found this wiring diagram of the cruise control. The red arrow is one option to tap 12V for the light. But in that case the light would come and stay on when the switch is set at the 'on' position. Even if the cruise control is disengaged or not set yet.
The green arrow points to a 12V supply to the vacuum pump. I'm not sure if this one is on all the time or only if the cruise control is set at 'on' or only when the cruise control is engaged?
I've used the search and found a few people who have CC in their 480. But there is not much to find about the light. Anyone who has a 'cruise' light working? Or has a great idea of which I didn't think about, and that isn't selling the complete set to you
P5 = vacuum pump
Can't you just connect the light to the plus of the CC switch like you said in you first post? I think that's a lot easier then just find out how it's originally being made. The light is always burning when you've switched on the CC..
The CC was never installed at the factory but at the dealership so I think it was done the quickest way to let it work..
Good luck!
Good luck!
Auke
Volvo. for life
Volvo. for life
CC
it's the one from the vacuumpump you have to use, when you push the set button it has 12v on it so the one with the green arrow! But where do you put it in the connector behind the dash. It was made for the american market i think only the early models had them but i havent seen it working so far. I am busy installing a CC as wel, its not working so far
- Melvin480
Did you measure that there is 12V at the wire with the green arrow at your own cruise control? Or did you get this info from a scheme/manual. In that case I would really like to have that
I haven't got the dash out to check where I need to put the wire for the cruise light. In an old post on the forum someone mentioned that he had added a wire to the grey connector to supply the cruise light with 12V. I will try the same. If this fails for some reason, I've thought of an alternative. Then I will take the light bulb out of it's black socket and attach wires directly to the lightbulb (and make sure it doesn't connect to the dash circuit board anymore). That would always work.
What is the problem with your CC? Is the light not working or is the entire CC not working?
cc computer pin 1
I cannot measure 12 v because my cc isn't working at all But it should have 12v when cc engaged because this wire steers the vacuum to the vacuum-valve in the enginebay. it's on pin no.1 of the control unit. In the grey connector there is space for one wire i think(hope) maybe that is the one you need. I ordered the little female wire connector that fits into the grey connector at the dealer, from sweden they got it, so everything quit original . Now i have to measure all components in order to get it running.
- Melvin480
The way it works according to the scheme (or the way I see it is wrong...) is that the wire with the green arrow should have continue 12V on it when the cruise control is working. The vacuum is regulated by grounding the vacuumpump (pin 9) to increase the vacuum. When grounding a sort of release valve (pin 12) air is allowed to flow in to reduce the vacuum.
This however doesn't say anything about if there is 12V or not on the wire with the green arrow when the cruise control is at the 'on' position but not engaged. Or if there is 12V at the wire when it is set at 'off' (probably not).
So I would like to know where the information comes from to be sure. Do you have some document that mentions this? Otherwise I will probably just connect it to the wire with the red arrow.
The wire you've got from the dealer, which part number is that? Like to have it original too. Is it just a short piece of wire with the connector at one end? Or is it a 'complete' wire with at the other end something to connect it at the CC?
this is the correct answer, so if you want the lightbulb in the dash to be on only when the cruise is actually working pin 1 is the one you have to connect to the bulb.Melvin480 wrote:The way it works according to the scheme (or the way I see it is wrong...) is that the wire with the green arrow should have continue 12V on it when the cruise control is working.
it,s just the cable terminator not the wire. i will look for the part number in vadis.Melvin480 wrote:The wire you've got from the dealer, which part number is that? Like to have it original too. Is it just a short piece of wire with the connector at one end? Or is it a 'complete' wire with at the other end something to connect it at the CC?
- Melvin480
The red arrowed wire has 12V on it when the switch is set at 'on'. The brake/clutch switches open the circuit so the CC computer doesn't get 12V anymore and disengages the CC. The arrow is before the switches so won't be affected by these. I will use the green arrowed wire as you mentioned. Or attach a female spade connector at both places so I can change it if it's not working like it should.
Thanks for the part number. What do you mean by the terminator? Is it the metal pin of the wire that fits into the grey connector? So you can attach a piece of wire to it yourself. What did it costs? Shouldn't be much if is only the small metal pin.
yes that's what it is, a few euro's for 5 pieces if they are not availeble anymore I have a few. nowewhere else in the car they used this type of terminal connectors so they are hard to find i guesMelvin480 wrote:Thanks for the part number. What do you mean by the terminator? Is it the metal pin of the wire that fits into the grey connector? So you can attach a piece of wire to it yourself. What did it costs? Shouldn't be much if is only the small metal pin.
