High beams on both sides not functioning
- surrealjam
Hi there
The high beams on my Volvo 480es 1990 are not functioning. When I say highbeams, I mean the ones next to the permanent side lights...
I thought it could simply be the bulb, but after replacing that it is apparent the issue is more serious.
I checked the fuse (if I am reading the list correctly, it's fuse 16) and it looks ok. The same fuse controls the horn and that functions fine.
Does anyone have any suggestions as to what may be causing these lights not to functions?
Many thanks guys
Many thanks guys
- surrealjam
Hi Derek
It reads in the manual:
"Main Beam Flasher - pull towards steering wheel.
With retracted headlamps, Long range lamps come on instead of main beams
With ignition key removed, headlamps burn for 30 seconds"
My car does neither of these things
I also get a Bulb Failure Warning every time I start the car, but there aren't any other bulbs out other than these high beams.
I'm beginning to presume it may be the wiring - does any one know where to start looking?
I've got a bulb fail warning light on too, although it's temperamental, as it's actually the brake lights test light, and about 5/10 times I can stamp on the brake pedal immediately on turning the car on and it'll go off.
[b]2.0ES.[/b] - [b][url=http://volvo480.dragons.org.uk/forum/viewtopic.php?t=17327]Sold[/url][/b].
Hopefully for 2009 - 1.7 Turbo.
- surrealjam
Hi Yossarian
The bulb failure light, according to the instructions, is meant to stay on till you first use the brake pedal. So stamping on the brakes a few times probably should switch it off!
That's not to say I think the warning light is really doing its job properly. It seems pretty temperamental to me...
Yeh, as I said, sometimes it'll stay on, even though I know all the brake lights are working.
Although for the MOT I was told that a number plate bulb was broken, which would explain it as well.
Sorry I cannot help with your problem, though. I've only used main beams a couple of times as I don't venture into the country side at night, and I didn't even know about "long range lamps" until I opened this thread!
get a voltmeter and check the wire connectors to the bulb,
do the lights work normally and only fail on the flash from stalk?
look up a chart for the relays and see if one controls this (unlikely) but worh a try
the last function on the list I wouldnt worry about who would use it anyway and might not be enabled on your model..
as the manuals are year specific not model specific and there are huge differences between an s and an es
- surrealjam
Hi Jim
The lights simply don't work at all - from the stalk, from the switch by the heated seats or the "guide me home" function.
I didn't realise it would be so annoying, but I find myself reaching for it to flash people on and thank people but nothing happens
I guess I must be a compulsive flasher
- surrealjam
Martin-
The 'full-beam' lights on the pop-ups work fine when using the stalk - it's only the highbeam (when pop-ups are down) that don't work.
Do you still feel this could be an issue with the stalk? Also, I believe with the headlights on, the switch by the heated seats should turn them on... but that doesn't.
Problem with 480's electrics there not good to start with. The later models are better but now these cars are getting old.
Bit confused
So pop ups are OK
But you can not get the spot lights to stay on when the head lights are down?
but they do flash on the stalk ?
so I must be well confused and tired since just completed 144hr at work.
in short the spot lights only flash with a stalk. the button if on make the spot lights stay on only if main beam is on (pop up's UP and pull back stalk)
Bit confused
So pop ups are OK
- surrealjam
Hi Martin
Sorry if I confuse things.
I have NEVER got the highbeam lights (that's the ones next to side lights in my book) to work.
I believe, with no lights on, using the stalk you should be able to flash these highbeam lights? (for example, you want to let someone in in traffic)...
With the pop-ups open, I can get 'full beam' on the pop-ups to work but NOT the highbeam ones to work.
I have tried using the switch next to heated seats with the headlights on. I have tried using the switch and the stalk, but the only full-beams I get are from the pop-ups.
This means, at the moment, to flash my lights, I have to open the pop-ups which ain't very quick!!
I hope I haven't made this even less clear...
- surrealjam
- surrealjam
I am guessing the bulb failure warning is related to this issue then as I can't see any other bulbs out.
I can't really back this up, but I don't believe it is a stalk issue. Unfortunately, I'm down in Birmingham so it's not viable to test it with you, Jim! Thanks for the offer though.
It sounds like it could be relay related. Would this be contained in the unit under the bonnet, immediately infront of the dash?
- surrealjam
- surrealjam
haha. I think I've confused matters by going into too much detail.
Martin, the long and short of it:
1) I have replaced highbeam bulbs.
2) Checked fuse controlling highbeams.
3) Highbeam still does not function under any circumstances - I have tried all combination of things using the stalk and the switch by the heated seat controls.
In order to get a 'flash', I must raise the pop-ups first - not very practical
