sr480t
Post
by sr480t » Sun May 18, 2008 8:02 pm
My horn is blowing my 20amp fuse, however, when i change the fuse the long range lights still work, is the horn and the longe range lights on the same fuse and relay? Then if so then the horn is gone do people agree? Sham
sr480t
Post
by sr480t » Mon May 19, 2008 7:34 pm
Its ok Shamir, i have worked it out, its your horn. I disconnected one of the horns and changed the fuse and one works. Looking forward to my donor car. Thanks Sham.
