Pop up headlights sometimes stuck down
Starting a few weeks ago my pop up headlights have been occasionally not going up. When it works it works fine with no issues but maybe 10% of the times I start the car they don't work.
Any ideas on how to fix this?
You fix one problem and another shows up
'94 Volvo 480 GT (project)
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Re: Pop up headlights sometimes stuck down
Try to give them a good exercising. Either by putting them up/down yourself for a few minutes or searching on here for the solution (Brinkir likely posted this plus a good pic) where you bridge a few relay contacts, override the bonnet safety over-ride switch and leave them popping for 10 mins or so. This cleans up the contacts in the relays and the motors.
First thing I'd check is the relay, sounds like the most likely culprit. There is a post somewhere showing bridging the relay contacts to give the motors a work out. Also probably worth mentioning at this point to check the gas struts. If they're worn out, the motors will be under more strain and eventually stop working. One of my pop ups was slower to lift than the other, eventually the motor gave up.
Current: 480 GT 2.0 '94 in Red
Previous: 480 ES 2.0 '93 in White K464SWP -Sold in 2009. Presumed dead
Oh yeah that too! new gas struts are a good idea too to take the strain off the motors
Thanks for the advice
Interestingly taking the headlight switch/dial out and putting it back in seems to temporarily fix the problem
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Ahh, could be a loose or dirty connection in the switch or the connector then.
https://imgur.com/a/Ziqa2Tw
Has anyone got pictures of the light switch pins? It looks like one might be snapped?
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
Here's mine. It appears that what looks like a broken pin is actually meant to be like that.
https://flic.kr/p/2mXUN3x
The headlights do seem to pop up with the ignition off, I have only tried it once so I don't know how reliable this is
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
So far turning the headlights on with the ignition off has worked every time. Does anyone know what makes this method so reliable?
'98 BMW Z3 (daily)
'98 BMW Z3 (daily)
