How to connect the towbar electrics? (bulb failure system)
Well, holiday is coming and I'm going to travel with my 480 and a little trailer towards Italy...
So, this weekend I bought a towbar... (I can do this, cause I'm Dutch )
The towbar is original Volvo...
But:
How do I connect the electrics, so that the bulb failure system still works?
I've done a search, but could'nt find an answer...
I've read something about some sort of a 'relay box' which is needed?
Who will help?
But:
Who will help?
- 480 Veteran
The bulb failure detector reacts on a difference in current between the left and right side of the car, except for the high-level brake light, for which a resistor is build in. So whenever one adds a load, it should be done symmetrically.
The indicator lights are not run through the detector.
You should be able to connect tail- and brakelights parallel to the existing ones, providing the loads are equal on both sides. And, of course, don't forget to adapt the fuses.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
Well, thats the 'problem'.Robou wrote:The bulb failure detector reacts on a difference in current between the left and right side of the car, except for the high-level brake light, for which a resistor is build in. So whenever one adds a load, it should be done symmetrically.
The connector for the towbar has 7 pins,
-mass
-light left
-light right
-indicator left
-indicator right
-brakelights
-constant 12v supply
That means, that the 'normal lights' won't be a problem, but the brake light does, since I only got 'one pin' in the connector which feeds the two brakelights of the trailer...
@ aibast,
I'll give the local Volvo dealer a call in the morning, perhaps they can tell me more... I'm curious what the price of such a device is
Connect a diode in each wire from the car to the one wire of your trailer connector. These diodes are cheap and will do the trick. The specs are low voltage, 5 Amp, this will ample do for two 20W bulbs.
If you don't know what a diode is and/or where to get them, pm me.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
Ok, that's something I didn't think about! Thanks for the answer!
I know what a diode is, but I think I don't understand how this should work.
Is it the trick that when I use a diode, the 'bulb failure system' doesn't 'see' the extra load of a second bulb? Cause the diode prevents any 'feedback' (don't know how to discribe it) to the bulb failure system?
How could I be so stupid not to think of thatRobou wrote: If not, why not make connections before the detector?
Thanks! I think that's by far the best solution!
Ok, now I'm curious if you have a bright solution for this one:
In the Netherlands, a trailer has to have a fog light.
But, when the fog light of the trailer is on, the rear fog light of the car is not allowed to be on...
Of course I could do this with a manual switch, but why go the easy way if the hard way is nicer
So, what I want is the following: When I connect the plug of the trailer, the power supply for the vehicle's rear fog light should be interrupted...
ps. when I'm done mounting the towbar, I'll put a 'how to' on the forum, the info of this thread will be in there also...
Grtz, Thijs
I wonder if this subject has any common interest and deserves a place in a "how to", but anyway:
One is only allowed to use a fog light when the rear lights are on, so if you have a spare connector in your trailer plug feed the live of your trailer's rear lights back to the coil of a relais, of which the n.c. is connected to your car's fog light and the n.o. to your trailer's fog light.
This is the only d.i.y. solution I can think of.
Any other possibility should use a voltage drop in the wiring, which triggers some simple electronics which in turn triggers the relais.
Too old to bother
480 Turbo midst '91
480 Turbo midst '91
