![Image](http://www.db-hp.ee/dev/shop_img/419o.jpg)
A/f Meter install?
A/f Meter install?
Has anyone added a A/F meter to there car? I would like to know where you hooked up the wires and where have you placed it in the dash. I was thinking of fabing a box for it in to the space unter the seatheating buttons and replacing the headligth hight adjuster that doesn't work.
This narrowband is going in.
1996 850R 2.0 T5 - "Beebi R"
1994 480 Turbo - RichMod - sold to get the R
1992 850 2,5 20V - sold to get the R
1987 744 TIC - Haas Tuning - totaled by BMW
1973 142 GL B20E - sold
i have installed a similar one in the dashboard, instead of the vertical air vent. another good position would be the a-pillar.
i've also tried the position under the seat-heating switches, but since the a/f ratio can change fast its not easy to look at the gauge all the time while driving![Smile :)](./images/smilies/icon_smile.gif)
i wouldnt recommend you to buy this type of a/f gauge because they are imprecise, the best thing is to fit a small voltmeter display or the led type a/f meter
[img]http://img.photobucket.com/albums/0903/Rednaxela999/d15baeb3.jpg[/img]
Stripping my turbo: [url]http://www.480.hazelnet.de[/url]
OK, thanks. I think the Voltmeter would be a good idea. But this thing is a bit show alsoRed wrote:i have installed a similar one in the dashboard, instead of the vertical air vent. another good position would be the a-pillar.
- martinholmesuk
thanksmartinholmesuk wrote:pin 20 of fuel ecu (turbo 480) is the signal
Why is it useless? What does it do or show? Does it show anything?JohnTurbo wrote:I have that exact A/F meter installed.
Trying to find a picture but photobucket is down.
Its nearly entirely useless.
- JohnTurbo
http://volvo480.dragons.org.uk/forum/vi ... uge#107946
Theres my thread.
It flicks inbetween full lean and full rich at idle. Under acceleration it will occasionally pause at some random point on the scale.
It looks fancy but narrow band A/F meters are very little use, at least on the 480.
I wonder if modern cars keep the lambda under tighter control so that these gauges are of more use.
To be fair you can kinda glean an indication of your fuel situation from it with a little poetic licence, but if you were thinking of using it to adjust your maf settings etc its no substitute for a wideband gauge.
Theres my thread.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
- 480 Veteran
Narrow band sensors are only for getting cruise conditions right. The ECU will oscillate between lean and rich. Under wide open throttle, it won't tell you anything useful. Narrow band can only really measure 14.7:1 and thats it, if you try tuning an engine, especially turbo using only a narrowband sensor you're likely to do a lot of damage.
- martinholmesuk
OK, I'll hook it up then and see what happens. Just came from a track and man was the 480 a fun to drive. Way better and faster thabn a 850 T5R. More responsice, you could force it trough the corners. Steering and handling is more agressive and gives more feedback. I just loved it. Did manage to blow of a wastegate actuator vacum hose. Thank god dint blow up my engine
In now even runs better
Headgasget is ok, no water in coolant and otherway around. Oul pressures ok. So no exessive pressure in the cranccase. I think this little overboost didn't hurt the engine. Can't wayt for nex time. Some guys by the track asked my companion (the 850T5R ovner) "What the hell is uiber that cars hood? That car is insane"
Hi aibast, Hi every body,
After I changed the fuel regulator with a new one which I can set it as I want , I need this gauge!
I use an Auto gauge one
Take the 12V line from the sound stereo line!
And the signal line connected to the signal wire which comes from the Lambda Sensor.
The lambda sensor has 3 wires (2 white and one black)
The black one is for the signal.
You can find it under the battery
Many times the fuel comes lean so I have to increase the fuel pressure!
Anyway, I'll post a pic ASAP to show you where I fixed it on the dashboard.
As they said, you need a very clear to view area because it's changing rapidly.
Cheers.
Cheers.
Proud to be the only Syrian guy over here!
[img]http://www.bassool.com/up/store/sign-volvo2.jpg[/img]
