i was on about an external tdc sensor haz , i thought you needed one of them to have the timing sorted after a cam shaft change ?haz@nocturnal_development wrote:this is a none turbo thread martin
shakal, what do ya mean there's no tdc sensor? so how does the electrics know where the engines at?
lol @ carb freeze, maybe if you had a large front mount cooler. there's enough heat in the engine bay to prevent this if it was a problem. bin that air box
equal length is just that, each runner is of equal length. the exhaust flow pulses and the equal length helps the gases flow smoother.
haz
on my f3p engined renault 19 ,i had a beautifull sound around 3.5k and over with a open air filter . and i am hoping to get the same on this engine
so what sort of air filter am i looking for ,a cone type that connects to the airbox ????(the standard filter in box removed obviously )
