any ideas ?
My friends 480 turbo 1989, ( the lot of discussed about former car of vince)
suddently had this problem, as driving. the car is now even slower than an es. I noticed the orange (single print) boost controller was warm
also noticable is the fact that it runs far to rich, because the exhaust is "bubbling" as you release the throttle.
of course, the turbo pressure gauge only slightly lifts in the white yield ( used to run deep into the red, remember the pictures)
We hope its nothing mecannical, normally this is not the case in a 480, but this thing is altered to the max, which is no good for reliability.
the odds are highest is something electric. Lets hope it is something simple.
any ideas ?
ex-canon, no more than 4000 rpm under load, bubbling exhaust
- volvofox
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- volvofox
well, maybe i wasn't clear enough. the exhaust smells like petrol, and it sounds like backfiring small amounts of fuel in the exhaust (bubbling. (maybe poorly described.)
I advised him (maybe i do myselves) to do the audible and/or the electric injector test. I also wonder if it has anything to do with the lambda sonde.
he himnselves things he has a vacuum leak on the serving side of the waste gate, so its opened a bit, and leaking air towards the exhaust, so the lambda sond finds oxigen, and making the mixture heavier.
I thingk the part of this story the waste gate is dumping in the exhaust b-sh*t (it is dumping in the low "pressure" side of the turbo inlet ?)
Note that he said something was loose at the exhaust.
I think the fact that the car is still leaking vacuum through the brake servo has nothing to do with this directly.
any comments ?
any comments ?
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
- dragon
- Volvo 480 Club Europe CREW
By the bubbling, do you mean a small set fast-happening of mini-explosions in the exhaust, a bit like the sound rally cars make sometimes? (or a bit like farting on a box lid? ) My car makes a noise similar to this if I allow the revs past 5k underacceleration, it hits 5k and the power goes, and when I release the accelerator, this set of small explosions happen. It is caused by the car leaning out and edging towards detonation in my case. Perhaps the fuel supply needs to be looked at on this car?
Gaz Wilson
Gaz Wilson
- volvofox
yes, it has an error with the effect of over fueling tghe exhaust even smells of petrol. he has something loose there and thinks of closing a hole there. as it is in front of the lambda sonde it can also influence the system (it measures oxigen, and than makes the mixture richer) I don't know about that, i havent seen it from below-yet
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
