ARE there a forged pistons and rods for B18FT?
Hi guys,
I have a clio with F3p and I turbocharged it with 10 psi boost. Does any body know if there are a forged piston that fits to b18ft which is the same block as mine? And does anybody know about the Crank signal?
- JohnTurbo
I have a feeling that some of the components in the b18ft are forged as standard, but i don't know if this goes as far as the pistons. The man to ask about this kinda thing is on a long-term afk at the moment.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
Re: ARE there a forged pistons and rods for B18FT?
That's the rsi engine...yeah ???mancolog wrote:Hi guys,
82mm bore as opposed to 81mm bore on b18ft
what u want to know bout the crank signal...???
Oh, and i can get a multilayer steel head gasket for those engines.
B18FT have forged conrods and pistons.Theyre made for Porsche by Accralite then delivered to Volvo.
When Rich Pruen returns hes a bit of a guru on this stuff guys!
I'm No Longer Here :(
Rich is around still just having problems getting back on the net. I'm in regular contact and this topic seems to cover mine and rich's latest project...
As the engine is based on a diesel engine, the bottom end is more than capable around 300 bhp with no modification as i understand it. The pistons and head however are the weak spot. Forged pistons are gonna cost a mint so we're taking a different root.
We've machined the pistons to lower the compression ratio slightly and balanced them. We're currently finishing off the heads... opening up the ports etc. Next stop ceramic treatment allowing up to 2600'C very briefly....
Haven't decided what's happening with head gasket yet. The standard one is pretty strong.
We're contemplating maybe doing short runs of pistons & heads if we get any interest and the prototypes work. It' s quite expensive but the benefits and results should be awesome.
Regards, Edd.
Regards, Edd.
www.teamvolvo.co.uk
www.teamvolvo.co.uk
the rsi engine
yes it is an rsi engine. So b18ft rods would be a good modigfication for my engine since they are forged? is that what I am understanding?
by the way ( overboost) How can I get that gasket from you? Im in USA for couple months. By the way there are a lot of companys that makes forged piston below 600$ I think its not that bad ...
I want to know the crank signal to get a advanced engine menagement system... they are asking me. is it 60-2 or 32-2 or what ever it is if somebody know please let me know.
You need to look at www.fastchip.nl for your ECU problems. Most engines B18E,EP,FT and early B20F) use 40 teeth flywheel. Later B20F and B18FT (from 1994) use an other flywheel with different number of teeth. (I dont know it )
AKA EB
