whats the difference
between the black manifold 480 turbo lump and the silver one.
if i bought a 89 model are there any parts i could take from the newer models that would be better?
cheers guys.
cheers guys.
***CAR FOR SALE 2K AND ITS YOURS***
- volvofox
the silver one is probably sandblasted, like my friends car. the ones with the round, tube like manifoild have no turbo.
Maybe you can refer better to the parts catalogue, there is probably an answer to your question. there is a link on the clubsite , if you want it downloaded.
Luck
JPF
Luck
JPF
luck,
JPF
Nomen est Omen
JPF
Nomen est Omen
No, i'm sure there are 2 types as king_j first suggests. Have no idea why. They seem to have changed at '92. But as volvovox says, if it just the colour you dont like, then have it blasted. A friend of mine did his his with a wire brush! Looked fine.
Suppose thats the change between a mkI and II. I know the clutch is bigger on the later from my recent experience... Other than that i dont know??
You should probably be asking what differences there are between the MKI's and MKII's cos i have no idea...
- Jamo
LOL Sandblasted!!!! LOL
Black is pre 1992
Silver is 1992 onwards.
It reflects the different engine type of the turbo of which there are 3 in total.
If it's a black manifold it's MK 1, you can also tell by the idle valve where the valve pipes will be at a 180 % angle.
MK2 will be silver and the idle valve pipes will be at a 90 % angle.
MK3 engine, there is a brake servo and the abs resevior is small and yellow.
There are other differences in pipping and the air recirc but those are the main ones visible.
Black is pre 1992
- Jamo
ABS was standard on the turbo for all U.K cars although this is not the case with our european cousins.
You can tell, open the boot and open the left hand box space at the back and in there should be the silver abs brain computer.
