Shimming tappets on time
Hi!
I was hoping someone will be able to help me with regards to shimming tappets.....
I dont see it written about on our Forum so I was hoping someone may be able to post a "How to"
I know that if it is neglected your valves can bounce like buggery and naff yer engine,so fairly important I thought........
I'm No Longer Here :(
- rpruen
Re: Shimming tappets on time
It's not that easy. You also need the shims, it's better to let a VOlvo specialist do it, as they have all the tools needed to thake the shims out and fit new ones.catgroom wrote:Hi!
You can do it with a couple of flat screwdrives, and two people. Best find a friend who isn't too woried about fingertips though! Because if the screwdrives slip, then fingers in the way will get hurt.
I guess you can get a tool from somewhere to hold the tapet down, while the shims are taken out, but it's likely to cost more than a garage will charge.
Richard
Car Status: Squashed :(
Now have 765 GLE 2.8 V6
- chris1roll
It only cost £80 when I had formula do mine. It only needed 2 replacing, and the engines done 173k now...
They would have lent me the tool, but I really couldn'r be arsed, because you've got to take it all apart, measure up and calculate, and then go and get the right ones.....tricky cos your car will have no inlet manifold or rocker cover, or indeed any tappets!
2001 V70 XC 2.5T
1989 744 GL Auto
1989 744 GL Auto
ok
Right,well,assuming Im a bit thick here ( !),are there any warning signs that they are in need of doing.I say this as theres the injectors that tick and the usual slight tappety noise which on my 2 started at 75-80k
- chris1roll
- Ben Harris
The "official" Volvo way.....
- JohnTurbo
Thats how i do it benji...had lots of fun with my panda, had camshaft reprofiled, so had to put spacers under the shims, which were innitially too soft and got thinner with time. Eventually got it all sorted.
I had 24 shims to play with though, and i still had to buy 3.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
What was it with pandas and tappets, they really did need them checked regularly, i know the 4x4 had special profile cams to help them get a bigger torque figure, and i used to adjust those at least once every six months.
That 4x4 of mine used to go anywhere, awesome little car, shame they rust so badly.
2.0l es single seater!!!
