MatBat
Post
by MatBat » Mon Nov 17, 2003 4:14 pm
No not from the wheel arches
What is the procedure/method of removing a catayitic converter,
1996 Mini Classic 1275.
martinholmesuk
Post
by martinholmesuk » Mon Nov 17, 2003 4:38 pm
unbolt (2 on each end) becareful and dont drop it.
then unscrew the sensor! YAY! Your need new gaskets.
MatBat
Post
by MatBat » Mon Nov 17, 2003 5:17 pm
What should one do with the sensor? doesn't this adjust the mixture etc.
Post
by pol » Mon Nov 17, 2003 5:42 pm
Yeah, you'll need to keep the sensor. If you're buying a de-cat pipe, you can get them with the thread for the sensor, or if you're breaking up the original, just put it back in when you've finished smashing!
MatBat
Post
by MatBat » Mon Nov 17, 2003 5:44 pm
just like to be sure before I screw around with it.
Post
by pol » Mon Nov 17, 2003 5:50 pm
I unplugged my lambda sensor from under the battery tray and cut any cable ties before I took the cat off. Just because it was pretty hard to remove the sensor from under the car.
