B20F... swap compatibility
Keyz
Post by Keyz » Fri Nov 08, 2024 11:07 am
Hi,
I'm searching for 480 from 94' with B20F 106, a spare engine.
I've found other B20F from a 440 but not with the same numbers after, with 208 instead of 106... Will they be compatible?
Re: B20F... swap compatibility
Post by jifflemon » Fri Nov 08, 2024 11:26 am
In theory, yes....
What colours are the dipsticks on both engines?
Keyz
Post by Keyz » Fri Nov 08, 2024 12:48 pm
Red for B20F 116 and green for B20F 208.
What does it mean, different oil grade?
What are the 3 final numbers.
Here's pictures of the engine:
https://ovoko.fr/les-pieces/rct683882-b ... bIEALw_wcB
Post by Alan 480 » Fri Nov 08, 2024 2:23 pm
Red for B20F 106 and green for B20F 208.
As far as I'm aware the change of dipstick colour was ONLY to signify that the engine mangement settings had been changed (possibly a different ECU?)
The information is on here........
viewtopic.php?f=11&t=35813&p=216279&hil ... ck#p216279
Post by jifflemon » Fri Nov 08, 2024 2:44 pm
Keyz
Post by Keyz » Sat Nov 09, 2024 7:47 pm
They are differents. So I would better search one B20F 116, with red dipstick...
Thijs480ES
Post by Thijs480ES » Mon Nov 11, 2024 5:05 pm
In Holland we prefer the green dipstick. There is a saying about the red dipstick that that engine uses more oil! I can't tell you why tho...
480ES Dark Grey Metallic 323 '95, Vega rims, DBS spoiler, Palm Beach wheel, Venetian Blinds, Snow Cap
Post by WillC9303 » Mon Nov 11, 2024 9:00 pm
Mine is a red dipstick and it never uses a drop of oil. I only ever have to put oil in it once a year when I'm servicing it!
