Exhaust line too low
Keyz
Post by Keyz » Thu Sep 05, 2024 2:52 pm
Exhaust line vas been changed, but it's too low... How to properly adjust it, so it goes in its couloir?
Re: Exhaust line too low
Post by jifflemon » Fri Sep 06, 2024 8:31 am
The usual problem point is where the middle section connects to the rear silencer. If the pipe isn’t pushed all the way, the centre section will hang low, and your rear silencer will bang on the crossmember when you go over bumps
Keyz
Post by Keyz » Thu Sep 12, 2024 5:03 pm
Ok thanks, yes, that's the case, there's differents models past the years... In the last series the middle silencer was split in 3 parts.
