Boost/ stuttering problems
Posted: Mon Sep 18, 2023 10:41 am
To explain it a bit better, when I get into the boost area, around 0.4bar, the car starts stuttering in all gears and then accelerates normal ish- boost jumps to 1 bar, in 1 and 2 gear. 3 gear the stuttering is so violent that I am too afraid to continue pressing the pedal.
My ECU has the roboumod, and o have just reset it and tried again with the same results.
I have checked the spark plugs, they seem a bit lean,
Recenty I have changed the fuel pump for a warlboro 255lph pump, but until yesterday the car was driving normally with it installed.
I have played with the maf a long time ago, that could be a problem, but I'm suspecting a stuck Westgate or a faulty boost controlel.
If anyone has any idea help would be appriciated
