Starts Fine then Cuts Out When Warm
TheRicer
Re: Starts Fine then Cuts Out When Warm
Post by TheRicer » Sun Feb 28, 2021 12:57 pm
Sun Feb 28, 2021 11:04 am
Glad this could be sorted out, odd how it can just be a small thing causing such issue!
Agreed, I was both suspicious and amazed.
Sun Feb 28, 2021 11:35 am
Idle adjust screw???
There's a screw on the throttle body that adjusts the idle yes? At least it did when I adjusted it.
