Rough running - B18FT
djbengan
Post by djbengan » Fri Nov 01, 2019 1:36 pm
Hello!
i'm in desperate need of help with my 480 Turbo from 88.
Problem:
Fuel or spark cut when going "positive" on boost gauge, loud pops/bangs from engine bay when trying to push anyway(does not sound like detonation/knock), no power and a strange idle jumping pattern that needs a good rev to snap out of.
Done so far:
New plugs, checked leads, checked and cleaned rotor housing and arm, new coil lead, new fuel filter, sprayed and replaced vacuum hoses, new air intake hoses, new MAF, new intake gasket, cleaned and checked injectors, checked ground points on engine, cleaned battery terminals.
Might be related:
Long time from crank to start, sometimes 1-2 minutes(10+ tries), seems like the fuel system is loosing pressure when not running, bad check valve somewhere?
The symptom is similar or the same that i had when my air intake hose was bust, is there a leak somewhere that i am missing?
480 Turbo 1988
Southeast Sweden
djbengan
Re: Rough running - B18FT
Post by djbengan » Fri Nov 01, 2019 6:12 pm
Just for clarification, I've volume tested the fuel pump by measuring. Seemed fine, but not tested the pressure.
480 Turbo 1988
Southeast Sweden
JP
Post by JP » Fri Nov 01, 2019 8:05 pm
Check MAF and ECT. Are the plugs getting black? Black smoke when accelerating?. This seems MAF related although it can also be ECU failure ( rare ). You should get 1L/30sec at the return hose.
Check throttle potentiometer also, and knock sensor
Post by jifflemon » Sat Nov 02, 2019 2:49 pm
Hello!
Problem:
Done so far:
Might be related:
You running standard ECU and boost? Any modifications ?
djbengan
Post by djbengan » Sat Nov 02, 2019 9:32 pm
I got an robou modded ECU but also the original ecu, same problem with both. The coil is not original, but also nothing special. Otherwise full stock.
480 Turbo 1988
Southeast Sweden
djbengan
Post by djbengan » Sat Nov 02, 2019 9:55 pm
Sorry, but what is the ECT? Plugs ashy, exhaust fine.
480 Turbo 1988
Southeast Sweden
Robou
Post by Robou » Sat Nov 02, 2019 10:48 pm
All symptoms, except the long time to start, sound like being caused by the MAF. Check first if you replaced it by the correct type, number ending by 007 or 021. Then clean the connector and if no success move the wiring to and fro. You may reconnect a broken wire in doing so.
When idling is normal again you know you found the culprit.
Too old to bother
480 Turbo midst '91
JohnTurbo
Post by JohnTurbo » Sun Nov 03, 2019 10:57 am
Sounds like an air leak.
Some bolt holes on the inlet manifold go right through. Thats a typical problem spot.
Otherwise seal up the manifold end of the inlet tract, and blow in the air filter end to see if it pressurises.
Or put a tyre valve in a jamjar lid and use a compressor.
Past:
94 Turbo - Red
92 Turbo - Red
90 Turbo - Silver
Now:
00 Exige
15 GKD Legend
16 Skoda Superb
djbengan
Post by djbengan » Tue Nov 05, 2019 9:51 am
Something worked, the cables/connector going to the MAF was not in very good shape when I removed the grommet, but the knock sensor cable was also damaged, so one of them maybe? There is also something wrong with the crankcase ventilation hoses, check valve is not sealing on the oil catcher thing and the check valve seems to be non functional as well.
But all in all the car is drivable again!
Will probably do the air leak test anyway, the robou ECU is not happy with the state of the car.
Thanks alot for the help! Will update when I have a definite answer.
480 Turbo 1988
Southeast Sweden
djbengan
Post by djbengan » Sat Apr 18, 2020 9:15 am
After winter sleep, the car lost it completely. Not sure what is what anymore. :wall: Runs for a few seconds, then vacuum creeps up towards zero and it stalls.
A little throttle added to get enough time for a movie.
https://photos.app.goo.gl/4jTpjGcpuQfbPeS17
480 Turbo 1988
Southeast Sweden
JP
Post by JP » Sat Apr 18, 2020 10:58 am
When the engine begins to loose vacuum, is the idle steady or is it loosing rpm?
djbengan
Post by djbengan » Sat Apr 18, 2020 11:24 am
The rpm drops as the vacuum goes up, pressing the throttle does nothing.
480 Turbo 1988
Southeast Sweden
