Vibration noise
teschio79
Vibration noise
Post by teschio79 » Wed Aug 14, 2019 12:28 pm
Good morning , i had Bought a 95 turbo past week ( about 20 years ago my first car was a 1990 white turbo ).
The car is in very good conditions, but there is only a problem, around 1800-2500 rpm the noise is very loud. Seems that the engine transmitt the vibration to all the car , i think there is some problems with subframe silent block , correct? What can i do for change ?
Re: Vibration noise
Post by jamescarruthers » Wed Aug 14, 2019 1:03 pm
Hello,
Based upon experience and reading on here, this is likely to be the rear gearbox mount‎ (often called engine mount). Of course you could be lucky and just have a misaligned exhaust.
You can't get new ones so if it is this, you'll have to get one from a scrapped car (all later cars have the same type, which is quieter but more fragile than the ‎earlier type).
Use the search function on here for 'rear engine mount' and 'rear gearbox mount' and you should find plenty of info. ‎
teschio79
Re: Vibration noise
Post by teschio79 » Wed Aug 14, 2019 6:00 pm
Sorry for my english, i am from Italy .
What can i do for test the mount ?
teschio79
Re: Vibration noise
Post by teschio79 » Tue Aug 20, 2019 10:17 pm
Hi, Someone can tell me how can i check the engine mounts?
Re: Vibration noise
Post by jifflemon » Wed Aug 21, 2019 8:26 am
is the car manual or automatic?
You need to get someone to load the engine (automatic - Put in drive whilst holding the brake, Manual, hold at biting point on clutch) whilst watching the engine.
the engine should move slightly - if the mount has gone, it'll leap about!
Re: Vibration noise
Post by Alan 480 » Wed Aug 21, 2019 11:35 am
I'd use REVERSE so that the mount will try and part away from the steel base plate/ sub-frame?
Re: Vibration noise
Post by jifflemon » Wed Aug 21, 2019 12:13 pm
Ah, very good point! Yes, reverse gear would show it up much better
teschio79
Re: Vibration noise
Post by teschio79 » Wed Aug 21, 2019 2:47 pm
Hi, car is manual. The noise come up also in neutral gear and approx 2000 rpm , when i try to turn the steering ( with stopped car in neutral gear) The noise increase.
Possible subframe bushes?
Re: Vibration noise
Post by Alan 480 » Wed Aug 21, 2019 5:51 pm
turning steering wheel suggests to me an issue with power steering, check fluid level first?
teschio79
Re: Vibration noise
Post by teschio79 » Wed Aug 21, 2019 7:51 pm
Fluid is ok. I mean that when Turn The strearing , The subframe is more solicited and vibrations increases.
teschio79
Re: Vibration noise
Post by teschio79 » Fri Sep 06, 2019 5:47 pm
Maybe i seen the gear mount damaged, if i move the engine with hands there is a suspect movement on that mount. But my question is : in that car, Whit 150000 km and 23 years hold , is better to change all the rubber parts? Like all the engine mounts and the bushing subframe?
Someone can tell me What is the exact code for gear mount? Is a 95 turbo manual. Thanks everyone wanna help me
Re: Vibration noise
Post by Alan 480 » Sat Sep 07, 2019 5:19 pm
REAR engine mounts are NOT available, although it appears that there is an ALFA part which might fit,assuming that they are available, which might not be the casse .. . .
do a search for 'rear engine mount' and you will find the trail
