Engine oil
Posted: Thu Mar 28, 2019 9:12 am
by Nashy48
Hi all has anyone used gulf tec plus oil it got a filter and 5 litres of oil £18
Re: Engine oil
Posted: Thu Mar 28, 2019 9:14 am
If it is 10W40 semi-synthetic it will be fine.
Does the filter have a non-return valve?
Re: Engine oil
Posted: Thu Mar 28, 2019 9:17 am
by Nashy48
Don’t know about filter ordered it from eurparts in 10w 40 how do I tell the difference about the filter
Re: Engine oil
Posted: Thu Mar 28, 2019 10:04 am
I think if you put your finger inside the hole on the bottom you should be able to feel a little spring loaded flap or something. Basically it stops the filter draining it's oil out when the engine isn't running. Cheap filters don't have this; the Volvo ones did so it's generally accepted that it's a good idea to fit an aftermarket one with this feature.
Re: Engine oil
Posted: Thu Mar 28, 2019 10:29 am
by dcwalker
I believe either Mann or Mahle filters have this feature and are/were suppliers to Volvo. However, genuine oil filters are still available from Volvo - one of the few things you can still get!
Not unduly expensive and well worth it in my view to ensure you have that non-return valve - it means the engine gets its oil faster on start up and gets up to pressure more quickly, which is all good for reducing engine wear.
I always use genuine oil filters on the 480s.
Re: Engine oil
Posted: Thu Mar 28, 2019 10:38 am
by Nashy48
What are crossland filters like as that’s what I’ve ordered
Re: Engine oil
Posted: Thu Mar 28, 2019 11:00 am
I don't really know mate, sorry. A quick Google shows them as very cheap filters which Euro Car Parts slap a once-good name on to (Euro bought the name)
Re: Engine oil
Posted: Thu Mar 28, 2019 11:18 am
by dcwalker
jamescarruthers wrote: ↑Thu Mar 28, 2019 11:00 am
Hate to be the bearer of bad tidings but it is as James says - Crossland was once a good name, but the quality of their parts now is poor. I would be pretty certain that their oil filter will be the simplest and cheapest possible, and it won't have the non-return valve.
Obviously it is entirely a matter for you, - doubtless the Crossland filter will do the job, but how well and for how long I wouldn't like to say. I don't know your circumstances and don't want to make any assumptions about them, but personally I don't think the oil filter is something you want to scrimp on if you don't have to...
Re: Engine oil
Posted: Thu Mar 28, 2019 12:24 pm
by Nashy48
Ok thanks for all your replies I will order a Volvo make I see they are on eBay
Re: Engine oil
Posted: Thu Mar 28, 2019 12:34 pm
by Alan 480
for tuppence i use MAHLE, have done for years, but I got caught with another make that didn't have the valve, red light always took a second to go out at start-up, so binned the filter
Re: Engine oil
Posted: Fri Mar 29, 2019 2:32 pm
by Nashy48
Went down to europarts picked my oil up the guy behind the counter new nothing about non return valve in the filter I had a look at the filter just looked the same as any other
