removing the outlet manifold, any tips?
timrosser
Post by timrosser » Wed Dec 05, 2018 11:05 am
Hi there,
Any tips regarding removing the outlet manifold on the 2.0? Is it a job for a novice?
Thanks!
Re: removing the outlet manifold, any tips?
Post by Alan 480 » Wed Dec 05, 2018 12:49 pm
exhaust manifold nuts onto the head is easy, getting the nuts that fix the down pipe onto manifold, not so :-(
easier if you have access under neath then you can 'drive-on' the best fitting socket and use LONG extensions, note that the size may 'not' be metric, six sided is best
the inlet manifold comes away at the same time though ;)
480 ES 2litre, C30 1.8ES, SS1 + more
timrosser
Post by timrosser » Fri Dec 07, 2018 10:01 pm
:-o Ok, think I might stick to the bumper then!
