Can anyone suggest which gasket manufacturers to avoid and which have pedigree? I'm doing the cylinder head gasket while engine is out.
I'm seeing Victor Reinz, Elring, Payen, Ajusa and Corteco in the listings.
Any recommendations?
Gasket manufacturer recommendations
Re: Gasket manufacturer recommendations
Anything that is OE quality - do not buy from online sources, where you are unsure of the buyer's repute - there are fakes everywhere. Out of those manufacturers, I recognise Payen, Elring and Corteco.
R
R
Victor Reinz are normally good!
'90 940 GL 2.0l Estate
'08 XC90 D5 SE Premium
I'm with Fraser, buy from your local motor factors, more chance a decent setjamescarruthers wrote: ↑Fri Aug 17, 2018 8:34 amCan anyone suggest which gasket manufacturers to avoid and which have pedigree? I'm doing the cylinder head gasket while engine is out.
but given the adage, 'if ain't broke , don't fix it', why ?
the head bolts are/were chuffing tight, I used a large 12" shifter around the arm of the allen key (rather than bend the arm)
Victor Reinz or Payen
my 2p
And remember the old line from Rolls Royce:
"Quality is remembered long after the price is forgotten"
my 2p
