Idle valve number
amazontommy
Idle valve number
Post by amazontommy » Sat Jun 30, 2018 4:47 pm
I’m been trying for some time making my 480 turbo to work but it keeps stalling and going rough, unable to keep idle rpms. So, I have changed loads of stuff but the problem remains. Next online is the idle valve control. Mine has bosch number 0280 140 502 but some say a Turbo (mine’s an -88) needs the 0280 140 546. So, which one should I have?
Additional info: the car has not run properly since I rather over enthusiasticly bought it over the phone. Yeah, I know, hugh mistake😬
amazontommy
Re: Idle valve number
Post by amazontommy » Wed Jul 04, 2018 7:35 am
Got hold of the Bosch parts ID.
This is their info on ICV for the turbo versions.
c/n up to 567599 Bosch 0280140501
c/n from 567600 Bosch 0280140546
Changed mine as it was a 0280140502 (not even for a Volvo) but did it fix the stalling? Nope.
Fuel filter next on the never ending list of probable causes.
frenchfries
Post by frenchfries » Wed Jul 04, 2018 7:54 am
Would it be easier to take it to Volvo? Might not be cheap to investigate but priceless from a iece of mind point of view
Post by jamescarruthers » Wed Jul 04, 2018 8:22 am
Are microswitches that control the idle valve working?
1987 Volvo 480 ES, 507274, 217 - Red
1992 Renault Master Mk. 1. Machzone Chateau camper. 2.0 LPG
J449 MNL -- ES
H858 FGV -- Turbo
White_Turbo
Post by White_Turbo » Thu Jan 10, 2019 8:08 pm
How to check it?
