Cambelt
Cambelt
Hello
Does anyone know with absolute certainty which cam-belt kit I need for Skip? With water pump I guess.
Chassis 581509
Model Year 1993
1.7 Turbo Auto
Merci
Chassis 581509
Model Year 1993
1.7 Turbo Auto
Merci
Re: Cambelt
Answered here mate: viewtopic.php?f=11&t=35601
Re: Cambelt
Damned
I knew it was there somewhere but could not find it. Would you change the water pump as well? Not sure where to find the proper one.
Re: Cambelt
Yes, change the water pump and use that as an opportunity to change the thermostat and flush & replace coolant (and the heater matrix!!!!!).
What temperature does Skip usually run at? Should sit in the 90's on the info centre display. I've had two thermostats get tired with age and made the cars run colder than they should have.
Re: Cambelt
Thermostat is Gates TH12888G1
Re: Cambelt
Water pump is nothing special. Put your details in at Mister-Auto and choose a decent quality one e.g. Valeo.
Maybe Jeff can advise other decent makes?
Re: Cambelt
Skip never reaches 90 degrees, same goes for oil temp.jamescarruthers wrote: ↑Wed Jun 27, 2018 9:49 amYes, change the water pump and use that as an opportunity to change the thermostat and flush & replace coolant (and the heater matrix!!!!!).
Re: Cambelt
That's too cold, definitely change the thermostat at the same time as the water pump
Re: Cambelt
He's a French man, with a French engine, French parts manufacturer is the ONLY answer.jamescarruthers wrote: ↑Wed Jun 27, 2018 9:54 amWater pump is nothing special. Put your details in at Mister-Auto and choose a decent quality one e.g. Valeo.
Valeo part numbers are:
819862 for the thermostat
506019 for the water pump
Re: Cambelt
Not just pretty faces after all you 2
Re: Cambelt
Hi all
Quick question: Do you need a tool to de-tension the aux belt for replacement?
Re: Cambelt
No, for the aux belt you should be able to judge it without tools, it isn't mega critical. I think your later car has a much better tensioning system that is on a threaded bar so you can wind in on and off easily.
A mechanic will be able to judge this from experience if you are leaving it to them. If you are doing it yourself, feel how tight it is now by trying to turn the belt 90 degrees between your thumb and forefinger and get it roughly the same when you replace it. Check it again in a few days after it has bedded in.
