Fuel tank
Fuel tank
Hi all
I refuelled Skip at the week end. It was down to the last 2 green bars and the red range alert had just come on but I only managed to put 50 and a bit litres.
Knowing Volvo, are they a bit cautious when it comes to the capacity once on Reserve?
Moi
Moi
Re: Fuel tank
60 litre tank isn't it?
Edit: and from the handbook......
Re: Fuel tank
Aha
Makes sense. Definitely the 60litres tank.
Oh God, I guess I should not mention the fact that I have a users manual upstairs. How embarrassing
Re: Fuel tank
You can check the calibration of the tank. Next time you fill up to the maximum, put the ignition on whilst holding the grey button without the hole down. Move the dial to vertical (fuel level) you'll see a report of how many litres the car thinks you have in.
Re: Fuel tank
Will do next week. Thanks for thatjamescarruthers wrote:You can check the calibration of the tank. Next time you fill up to the maximum, put the ignition on whilst holding the grey button without the hole down. Move the dial to vertical (fuel level) you'll see a report of how many litres the car thinks you have in.
Re: Fuel tank
And adjustment can be done by prising the little round plug out between the grey buttons. Insert a very thin Philips screwdriver to adjust the little potentiometer in there.
Theoretically a pin should get the little plug bit out but I've had some that I couldn't get out without slightly disassembling the switch assy!
Re: Fuel tank
It’s little gems of information like that, that make this place an absolute gold mine.
I know what i’m Doing when I fill the tank up for the October meet!
Re: Fuel tank
I think the official line isn't to set the tank to the actual size or else there'd be no reserve.
Haynes has the figure in from what I remember, it's something like 3 or 5 litres less that the 47L or 60L tank
Re: Fuel tank
for info I check it when tank is empty (nearly) and then confirm that it agrees when i add 40litres, TBH fairly accurate most of the time.
PS when the range gets to 11 iles the next step is ' - - - ' , which I took as being 'you're own your own from here pal'
Re: Fuel tank
Totally agree, to be bookmarked for when I have the dash back in.jifflemon wrote:It’s little gems of information like that, that make this place an absolute gold mine.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
Re: Fuel tank
