Emissions etc
Emissions etc
Post by Alan 480 » Sat Jul 15, 2017 10:32 am
Maybe wrong area,
last year MoT was comment that emissions were 'odd' so here is a trace (maybe not visible) showing the output from the lambda sensor
this look a bit slow but it is swinging up and down every second or so, slow enough that I can view on teh multi meter!! from about 0.15 V to 0.8V, when engine was off it was about 0.4V. Heater in sensor is getting 12V and about 3 ohm resistance.
any comments?
Re: Emissions etc
Post by jifflemon » Sat Jul 15, 2017 1:11 pm
Have you got the emissions print out? HC's and O2?
Re: Emissions etc
Post by Alan 480 » Sat Jul 15, 2017 3:20 pm
Some results over last couple of years:-
CO zero to 0.1
HC 8 to 22
Lambda 1.02 to 1.04 so just in at top-end and no more!
before swapped the sensor the HC was higher and Lambda lower (towards 1)
From what I can figure out a HIGH Lambda is weaker, so from a tree hugging aspect this should be good :wink:
PS is the image visible?
eye of ra
Re: Emissions etc
Post by eye of ra » Sat Jul 15, 2017 4:44 pm
I cant help with your problem sorry, but I can see the image.
480 ES Auto 1989
480 Celebration 187
480 ES Auto 1991
CLK430 Conv 2001
Hyundai i10 2015
