Timing belt
frenchfries
Timing belt
Post by frenchfries » Mon Jul 10, 2017 9:37 pm
Hi all
Skip will be at the garage for a few repairs and I will have the timing belt done as well.
As I mentioned before it was done last in 2010 and has since done 3000 miles. Should I go for the belt or a kit? Prices vary on Ebay, what would you suggest as I am likely to bring it to my Volvo guy :)
Re: Timing belt
Post by jifflemon » Thu Aug 17, 2017 12:04 pm
Do a kit - May as well replace the tensioners at the same time, so you've a level playing field to start from.
Re: Timing belt
Post by brinkie » Thu Aug 17, 2017 1:09 pm
Do a kit and replace the water pump and the alternator belts as well; it will set you back maybe 50 pounds extra but it will save you a lot of trouble in the future.
