Can j put V40 T4 engine into 480?
Re: Can j put V40 T4 engine into 480?
Anything is possible, with the right amount of work and engineering.
I believe there was a thread somewhere where someone had completed it; the pics had long since dissapeared though
Yes you can, with the right amount of tools, skills and time. Alternatively, you could look at Renault F-type engines, because they fit the gearbox and drive axles.
F-type engines ?
The engine used in the Volvo 400-series (and the 1.7 in the 300-series) are derived from Renault F-type engines, with modified cilinder head.
1721cc = F3N
1794cc = F3P
1998cc = F3R
Gearboxes I think are derived from Renault JB3 (all except Turbo) and JC5 (Turbo) but I am not sure which engines/model years got the JB3 and which one the stronger JC5.
Later Renault developed uprated engines with 4 valves per cilinder, the 2.0-16V in the Renault Mégane Coupe (F7N engine) gives 150 bhp. Same kind of gearboxes, you only have to find one with electronic speedometer to connect it to the 480.
1721cc = F3N
1794cc = F3P
1998cc = F3R
