Engine Type Query
ohdearme
Engine Type Query
Post by ohdearme » Fri Feb 17, 2017 1:42 pm
I am a bit confused about the type of engine I have in my 1991 480 ES Auto the tag in the engines shows:
"Model 480 B 18 EP, FT"
Sorry for sounding like a complete idiot but what does this mean, when I google it I get conflicting information.
Trevor
Red 480 ES Auto 1991
Bought 2016, hoping to use a weekend car in 2017
First classic car, learning a lot, but having fun
Re: Engine Type Query
Post by jifflemon » Fri Feb 17, 2017 4:52 pm
Where are you reading the data from? As I understand it, their two different (but similar) engines.
The B18 EP is 78Kw @ 5580rpm
The B18 FT is 88Kw @ 5400rpm
ohdearme
Post by ohdearme » Fri Feb 17, 2017 5:06 pm
It's typed exactly the same as my text but on a green sticker along with lots of other codes. Hopefully these photo links will work
Trevor
http://s36.photobucket.com/user/Datos_M ... sort=1&o=0
http://s36.photobucket.com/user/Datos_M ... sort=1&o=1
http://s36.photobucket.com/user/Datos_M ... sort=1&o=2
ohdearme
Post by ohdearme » Fri Feb 17, 2017 5:21 pm
Post by jifflemon » Fri Feb 17, 2017 6:17 pm
OK, that worked, but where's that label? Can you see anything on the engine plate? It's normally next to the dipstick on the block
ohdearme
Post by ohdearme » Fri Feb 17, 2017 6:29 pm
Ok I have updated the folder. The green stickers have the engine code I am querying. The only other plate or sticker I can find is the riveted plate.
That's all I have to go on.
Trevor
http://s36.photobucket.com/user/Datos_M ... ne%20codes
Post by jamescarruthers » Fri Feb 17, 2017 7:31 pm
Your VIN number states that you have a B18F engine
http://www.volvo-480-europe.org/volvo48 ... 5emc563362
You have to have joined the main site as a member to use this facility
Manufacturer code       xlb Volvo Cars Netherlands
Car type       e Volvo 480
Safety standard       x 3 point seat belts
Engine type       18 B18F-106
Transmission type       5 4-speed automatic gearbox with lock-up
Verification       e Europe
Modelyear       m 1991
Factory       c NedCar, Born (Netherlands)
Chassisnumber       563362 Perhaps car 261 constructed in 1991.
ohdearme
Post by ohdearme » Fri Feb 17, 2017 7:36 pm
Thanks James that's incredibly helpful information. Thanks Trevor :)
Post by brinkie » Sun Feb 19, 2017 1:57 pm
Skandix to the rescue :)
https://www.skandix.de/en/vehicle-selec ... &x=75&y=12
It's a 1990 B18FP with auto box. It does NOT have a B18F-engine, that is a very rare engine (same setup as the turbo engine, but without the turbo) producing only 95 PS and runs on low-octane fuel (RON 91, a.k.a. "Benzin unverbleit" in Germany).
Post by jamescarruthers » Sun Feb 19, 2017 3:19 pm
Hmmm that's odd! The VIN decoder on this site doesn't have the B18FP as an option.
I wonder if Daniel could change this?
"18" is states as B18F-106... he must mean FP.
ohdearme
Post by ohdearme » Sun Feb 19, 2017 4:10 pm
I am glad I asked the forum. :?
