Can anyone confirm if there is any difference in the starter motor for a 1990 Turbo (Orange ECUS) and starter motors from other years and engines?
Mine no longer works simply rattles and spins slowly or doesn't spin at all.
Thanks,
1st480
1990 Manual Turbo Starter Motor
Re: 1990 Manual Turbo Starter Motor
I've just been on eBay and they have one for the 88-91 and one for the 91-95 and both part numbers match.. I would double check though..
Someone will be along to clarify
93 480 Turbo white
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
with Roboumod
91 480 Turbo white
with Roboumod..
91 480 Es silver
To somewhat answer my own question, it appears that there are 2 options on starter motors;
Both will happily bolt in place, but one is a 9 tooth (believe these are for pre '91/92) the others are 10 tooth.
The later 10 tooth ones have a much thinner body, the 9 tooths are much fatter but I believe slightly lower power rated.
I'm not sure if there is any difference between turbo and non turbo, but it seems to fit in with the change in clutch diameter '91/92 and I would think explain one of the reasons you can't swap ecu colours without swapping flywheels.
Hopefully this might help someone in the future
1st480
1st480
