mystery roar
mystery roar
Post by glasgowjim » Wed Jul 15, 2015 3:02 pm
This is a new one on me ...
1.7 litre engine 1992 (old style engine mounts)
car has for the last couple of weeks sounded as if it has a sports exhaust !!!
engine performance is not affected acceleration idle fine :eek:
have checked......
exhaust no leaks
manifold no leaks or splits
is not burning oil /losing water e
rear engine mount seems ok (engine does not throw forward or back)
weird thing is it doesn't sound so bad from the outside but inside the car it does sound loud
a bit stumped on this one
this weekend I will try swapping over the old style engine mount and bracket for the new version . Already had a look and whoever designed this bracket really should see a doctor.
any ideas ?????
Van
Re: mystery roar
Post by Van » Wed Jul 15, 2015 5:30 pm
I've had something like this which turned out to be a loose panel inside the exhaust vibrating. At another time it was a center pipe just not fitting right, but you checked that.
Rob Houston
Re: mystery roar
Post by Rob Houston » Thu Jul 16, 2015 10:04 pm
Had the same on my previous Celebration. Sounded like a Ferrari on full chat inside. Outside just a wee bit noisy. This occurred three weeks after fitting a new back box; the only noticeable symptom was a bit more water vapour condensing from the exhaust. It turned out to be a loose baffle at the back end of the box.
Regards,
Rob H.
The car in front is possibly going to be a C30 - and it's staying there!
Previous: 1994 480 ES, 1994 480 GT, 1994 Celebration, 1995 Celebration #286, Celebration 293. All passed on to the BIg Crusher!https://www.volvo-480-europe.org/forum/ucp.php?i=ucp_profile&mode=signature#
POE
Re: mystery roar
Post by POE » Sat Jul 18, 2015 3:12 pm
Ive got loose bulkhead heat shield that sounds noisy inside car but nothing outside' Vibrates on revs inside car through steering rack
Re: mystery roar
Post by glasgowjim » Mon Oct 12, 2015 7:59 pm
Solved the problem and you are all wrong :rofl: :rofl: :rofl:
dont give up the day jobs yet guys :lol:
stirpped the wheel down and discovered the NSF wheel bearing was badly goosed. Got a new replacement and fitted it to the car .Result now runs as sweet as a nut ????? :wink:
Re: mystery roar
Post by Alan 480 » Sat Oct 17, 2015 5:03 pm
when the front wheel bearing went on the C30, it sounded more like a banshee than a ferrari!!
it still made it from Perth to ABZ, (via Loch Rannoch) but we took the coast road to keep speed down :wink:
